Share you NA build cost $$$
#81
Sorry, it's a 427. Goal is about 750HP crank. 600 through the stalled auto...
Cam is fairly mild for a 427 but I wanted something that would spin out to 7500 and still be easy enough to drive in traffic with the A/C on...
Cam Motion LLR 247/259 .688"/.671" 113.5+4 LSA
#83
Cool thread. Just for future posters: if you could add up all your costs to come up with a final $? I'm not going to sit here with a calc & add up all your costs. Lol.
#84
You guys have got it good in the states
LSX block $4300
machining $1800
callies crank and rods $3900
JE piston $1600
mamo heads , intake, rockers $12000
crower lifters $1300
pushrods $280
heads gaskets $430
assorted gaskets $270
rod and main bearings $460
valve covers $500
timing chain $230
mellings pump $380
arp studs n bolts $900
102mm throttle body $1100
Can $580
assembly $2200
1 7/8 extracters $690
TOTAL $32900
LSX block $4300
machining $1800
JE piston $1600
pushrods $280
heads gaskets $430
valve covers $500
timing chain $230
mellings pump $380
Can $580
assembly $2200
TOTAL $32900
#85
LSX block $4300
machining $1800
JE piston $1600
pushrods $280
heads gaskets $430
valve covers $500
timing chain $230
mellings pump $380
Can $580
assembly $2200
TOTAL $32900
LSX block $4300
machining $1800
JE piston $1600
pushrods $280
heads gaskets $430
valve covers $500
timing chain $230
mellings pump $380
Can $580
assembly $2200
TOTAL $32900
The following users liked this post:
JF74chevelle (01-15-2020)
SoFla01SSLookinstok (09-28-2019)
#87
simple cam swap basically.
Junk yard lq4 $600
862 heads $Free .99
Cam Motion Cam swap kit (cam/lifter/spring/pushrods) $887.54
Maintenance parts "while i'm in there" (oil pump, water pump, idler pulleys etc) $407.11
SS headers $100 from a buddy
Total $1994,65 total invested in my 6.0 for my swap. Just a simple cam swap, done the right way, is not cheap.
Junk yard lq4 $600
862 heads $Free .99
#89
Moderator
Received 1,838 Likes
Originally Posted by JakeFusion
"A lot."
#91
Heres the breakdown of my small budget build. I don't have the exact costs, but it should be close:
dissembled lq4 block and internals - $500
machine work, bearings, rings, assembly - $900
TEA heads - $2000ish including buying cores
lifters and trays - $250
straub bushing kit - $180
Pushrods - $100
Cam motion cam - $400
Oil pump - $100
Misc. gaskets and bolts - $400
headers and y pipe $400 - got the headers used
TSP exhaust $550
Misc fluids - $150
This doesnt include the new trans related stuff like a new PTC converter, SFI flexplate for the long crank lq4, fluids, then a tune.
If this motor needs to get pulled out again, then I'll probably use the block for a more max effort forged 370 ls3 top end build.
Pushrods - $100
Oil pump - $100
TSP exhaust $550
Misc fluids - $150
#93
LS1Tech Premium Sponsor
4.8 360 build
Machine work $450
Rods $330
Pistons $450
Rings $130
Crank $740
Balancing $200
Bearings $225
Complete gasket kit $330
Cam bearings $25
Billet timing set $89
Oil pump $95
Lifters $99
Trays $32
Rockers $230
Pushrods $100
Cam $389
Pac1219 $140
Heads (free)
Valves $199
Valve job $245
Block (free)
Assembly (free)
Basically $4500 for that complete setup. I may have missed a few odds and ends but the bulk of it is there.
Not bad for a fully forged kit. On to the next!!
Machine work $450
Rods $330
Pistons $450
Rings $130
Crank $740
Balancing $200
Bearings $225
Cam bearings $25
Oil pump $95
Lifters $99
Trays $32
Rockers $230
Pushrods $100
Cam $389
Pac1219 $140
Heads (free)
Valves $199
Valve job $245
Block (free)
Assembly (free)
#94
4.8 360 build
Machine work $450
Rods $330
Pistons $450
Rings $130
Crank $740
Balancing $200
Bearings $225
Cam bearings $25
Oil pump $95
Lifters $99
Trays $32
Rockers $230
Pushrods $100
Cam $389
Pac1219 $140
Heads (free)
Valves $199
Valve job $245
Block (free)
Assembly (free)
Machine work $450
Rods $330
Pistons $450
Rings $130
Crank $740
Balancing $200
Bearings $225
Cam bearings $25
Oil pump $95
Lifters $99
Trays $32
Rockers $230
Pushrods $100
Cam $389
Pac1219 $140
Heads (free)
Valves $199
Valve job $245
Block (free)
Assembly (free)
G Atsma (12-03-2019)
#97
wannafbody (01-22-2020)
