241 tea ported heads milled?
Old Feb 7, 2019 | 03:06 PM
02ls1camaroz28's Avatar
Default 241 tea ported heads milled?
i have a set of ported 241 heads that I’m debating on having milled for my ls1 car, the cam is 233/239 112 lsa at 600 lift. Texas speed said I could shave off .020 what do you guys recommend?
Old Feb 7, 2019 | 10:06 PM
Ls7colorado's Avatar
Old Feb 7, 2019 | 10:56 PM
I may try .025 and see if I can get away with it. I will ask the machinists.
Old Feb 7, 2019 | 11:59 PM
Why do that if you already have 2 opinions stating to do .020?? If both TSP and Ls7colorado think .020 is enough, why risk a problem??
Old Feb 8, 2019 | 07:27 AM
Tsp is a very reputable builder, what is another .005 gonna gain you other than slightly less valve clearance the compression increase will not even be noticeable
Old Feb 8, 2019 | 07:31 AM
AnotherWs6's Avatar
I wouldn't go over 20.
Old Feb 9, 2019 | 01:36 PM
You guys are right going to stick at .020 over and hope for 400whp. Any opinions 241 tea ported shaved .020 ls6 intake 233/239 tsp cam a4 car.
Old Feb 9, 2019 | 02:58 PM
Should be no problem with supporting mods
Old Feb 9, 2019 | 03:29 PM
I have Texas speed long tubes and an air box. What’s your dyno guess?
Old Feb 10, 2019 | 12:10 AM
should be over 400 even with an auto good intake would help a lot up top
Old Feb 10, 2019 | 10:17 AM
What’s your thoughts on the dorman ls2 intake
Old Feb 10, 2019 | 03:33 PM
I was thinking the ls6 intake was better than the ls2 have to search again I’m not farmiliar with the efi intakes.
i do know the FAST are way better
Old Feb 10, 2019 | 08:26 PM
The stock LS2 is not very good. By comparison, the Dorman LS2 is VERY good, comparable or even a bit better than the LS6, which Dorman also makes a copy of.
Old Feb 10, 2019 | 10:57 PM
I’ve looked at the dormans and I’m thinking about getting one and a 92mm throttle body. Fast are high!!!
