5.3 rebuild dod delete
Old Feb 12, 2019 | 12:42 PM
sbf2's Avatar
Default 5.3 rebuild dod delete
hi guys got a 07 Tahoe with a 5.3.gonna rebuild the engine.got a few questions.
1=will a ported ls6 oil pump work.
2=does anybody no what else ill need besides the ls2 timing cover to delete the dod
3.going with cam motion stg2 drop in cam,ls7 lifters trunion kit,ls6 springs.
what valley cover timing chain and or gear and someone had said about doing something to the oil pan,and a different pcv system
Old Feb 12, 2019 | 12:50 PM
JoeNova's Avatar
Restricted User
1. Yes.
2. The LS2 timing cover has nothing to do with deleting the DoD.
3. Why get a drop-in cam and then change valve springs? If you're going to be changing springs, why not get a more capable cam?
Old Feb 12, 2019 | 03:37 PM
sbf2's Avatar
Originally Posted by JoeNova
1. Yes.
the ls2 has the cam sensor on the timing cover thats gonna be needed when delete the dod cam and why would anyone reguild a engine with the same valve springs? and this is a daily driver not a hot rod or race vehicle so the cam i picked is great for what i want to do
Old Feb 12, 2019 | 04:01 PM
If the engine has DOD it already has the late timing cover with cam sensor. One look would tell you that.
Old Feb 12, 2019 | 04:27 PM
sbf2's Avatar
ok i just brought the vehicle sunday and havent payed any attention to the engine i just checked it yes it has the timing cover with cam sensor. so bascially all i need is cam and chain ?
Old Feb 12, 2019 | 05:52 PM
To fully delete DOD you need 8 more std. lifters, a full set of lifter trays, and an LS3-type valley cover.
Old Feb 12, 2019 | 05:56 PM
sbf2's Avatar
got it thanks when going to the ls3 valley cover is there anything thats has to be changed as far as pcv or catch can.
Old Feb 12, 2019 | 07:47 PM
I THINK the PCV system is the same between DOD/non-DOD engines. So no PCV changes as far as I know.
Old Mar 14, 2019 | 10:38 AM
The three bolts applies to how the sprocket bolts to the cam and has nothing to do with the cover.
DOD relates to the cam, lifters, and valley cover ONLY.
VVT is related to the cam, sprocket, and front cover ONLY.
The front cover is changed ONLY when converting FROM VVT to non-VVT.
Old Mar 14, 2019 | 12:56 PM
If he is changing from VVT to "normal", then yes a "normal" non-VVT cover is needed. A 3-bolt conversion is not what necessitates that however. 1-bolt cam non-VVT engines have the "normal" cover, and when switching them to 3-bolt cam, no cover change is needed.
And no, I don't do this for a living. I have studied LS engines for the last 4 years until I know just about every nut and bolt on them.
BTW, ALL VVT cams are single bolt whether aftermarket or not. They use the central single bolt to pump oil into the phaser.
Old Mar 14, 2019 | 02:11 PM
JoeNova's Avatar
Restricted User
Originally Posted by andy burdess
most delete cams will be 3 bolt. Or aftermarket with a travel limiter. Just giving him a heads up if he uses a 3 bolt cam gear he’ll need a different cover.
Not unless he is deleting VVT.
