L33 with BTR stage 3 n/a PTV issues?
Old Feb 15, 2019 | 08:38 PM
amm96rs's Avatar
Default L33 with BTR stage 3 n/a PTV issues?
Ok guys, I’ve searched and can’t find this exact setup anywhere. Is anyone running an L33 or any 5.3 with flat top pistons and no valve reliefs with a BTR stage 3 LS1/LS2 N/A cam? My heads have been milled .020 as well. I’m worried about piston to valve clearance, I got all the parts for next to nothing but don’t want to just destroy them. Should I be ok or no go?
Old Feb 16, 2019 | 06:50 AM
Ls7colorado's Avatar
I think it might be close, get some playdoh and check
Old Feb 16, 2019 | 08:10 AM
amm96rs's Avatar
That’s what I was thinking, I don’t have any solid lifters or anything like that to check with. Will the hydraulics collapse and give me a false reading? Also any idea what kind of clearance I need?
Old Feb 16, 2019 | 08:18 AM
98CayenneT/A's Avatar
Give this thread a quick read.https://ls1tech.com/forums/generatio...ve-method.html Much better way of checking PtV compared to dealing with clay on the piston tops.
I had .040" intake and .060" exhaust and ended up cutting .030" valve reliefs with the setup in my sig.
Old Feb 16, 2019 | 10:03 AM
just need a really light spring to have just enough pressure to hold the valve open. I’ve even used no spring before when I couldn’t find anything light enough.
That will keep the lifter from bleeding down any
EDit: just check the link above and that seems like a pretty good way to check!
Old Feb 16, 2019 | 10:52 AM
amm96rs's Avatar
Thanks guys. I’ll check measure it Monday before bolting the heads on. Hopefully I have enough clearance. Not wanting to machine more parts. Fingers crossed
Old Dec 23, 2021 | 07:50 AM
gleno97's Avatar
I know this thread is a few years old....but I'm considering doing this exact same thing to my L33. Can you please share your results?? I'm wondering how it turned out. Thanks!!
Old Dec 23, 2021 | 10:59 AM
amm96rs hasn't been here for over 2 years.
