cam gurus please step in....
needs-
car MUST take off from a dead stop like its stock. no bucking or wanting to stall or a hint of anything at low speeds. also a nice chop at idle and have GOOD low end power. from lets say 1500-6500rpms. has to pull well, something that rip the tires off the rim off idle and can also pull well on a highway run. would like to make 450rwhp+.
heads-
SPS cnc ported 243 heads. milled .030
.040 headgasket (questionable). depending how much compression we can run and still make sure everything will clear and be 93oct safe
intake/tb-
FAST 102mm intake fully ported by SPS and port matched to the heads
WARR 102mm TB port matched by SPS to the intake
exhaust-
speed engineering long tube headers 1-7/8s and hooker blackheart true duals (catless)
other-
25% underdrive pulley
now the off the shelf summit stg 1 specs are 222/233 .600/.575 115+3
the few changes i have made to maybe suit my needs better but not sure. just guessing here.
1- 222/233 .600/.575 114+3
2- 222/233 .600/.575 113+3
4- 222/233 .600/.600 114+3
5- 222/233 .600/.600 113+3
i know these are very small changes but im not cam person. just ideas from other cams iv looked at and also taking my wants into account.
would like to know everyone's opinion and suggestions.
he has my heads just about done. starting the intake and tb when everything gets there.
Gears really help with drive ability and bottom end. That can help open up cam choices.
The Summit 222/233 Ghost Cam or similar seems to be an excellent cam. However for more power other Summit cam looks good too the ~227/235 is sized one. With a 346 cube engine the 227ish duration intake is about the max before torque starts shifting to the right.
There are a lot of excellent ~227/235 is cams to consider too. I'd want 4.10's in any T56 car even a bolt on car. It's probably the most rewarding fun to drive mod for a T56 car other an aftermarket shifter and skip shift elimination.
Remember, stick the duration/lobe separation/advance into the calculator and it will tell you what's going to happen.
