Trying to figure out which cam for build
Cool. Did you run the time in your signature with that combo?
I would humbly submit the Cam Motion LS1 Titan 4, 227*/232* 113*+4* Adv.
as the ideal street/strip daily driver capable cam for your combination and
goals.
Good Luck
So, with those cam events and slightly biased intake overlap, I'd recommend a 229/237 113.5+3 combo. Using 370/362 lobes for .629/.615 lift numbers from TSP or Cam Motion.
It would make good power and drive great. I'd aim for 11.2:1-11.4:1 CR or so with it as well.
For compression I think they only make those heads in 62 and 68cc chambers so will probably have to go with the .041 gaskets. I also have a arp 12 point head balancer bolt ready to go and was planning on the ls2 trays as well.
I will look into a bigger lid and maf. What sizes would you suggest on those? 104 and 85? Unless Carl thinks I should go SD. I would definitely like to see your cammed cars manners this spring.
also research the 100mm maf, you will find they really arent that necessary on a 346. by far the easiest route is the 98/85 maf combo. finding the reducing coupler to work connecting the 100 maf to the 90mm tb is a pain
