Trying to figure out which cam for build
My goals are a very streetable/torquey 450+rwhp/400+ tq car that won't see track time any time soon. I have 93 octane available close by so am wanting to run mid to high 11s in compression. This is not my daily driver so when I drive it, I have fun and routinely like to spin the engine to mid 6 grand even on the street. I will be running stock size Sport Comp-2 BFGs for now. Since I am buying the heads from Texas Speed, I am going with their dual spring package with titanium retainers. I was also going to go with either the torquer V2 or V4 cam in the package as well, but am not sure if that would be the way to go or not for my goals in terms of combined drive-ability and power. I know something like the SSHT or SNS 2 cams might be better but wanted to solicit opinions based on the parts I'm using below on my build.
Here is the stuff I am going with on this build:
PRC as cast 225 62cc heads with hollow stem intake valves and either .051 GM MLS or Fel Pro .041 head gaskets
FAST 90 intake and WARR 92mm TB - already purchased and near breaking even after selling off my LS6 intake and stock tb
Powerbond 25% ud pulley
SE 1 7/8 headers to FM Merge dual 3" to single 4" to possibly 4" e-cutout and back to 3" LM1 currently on car (wanting to replace with something quieter as I'm sure this is going to be stupid loud)
42# injectors
TBD new clutch
Stock rockers with trunion upgrade
LS7 or Morel drop in lifters
LS2 timing chain
Melling standard replacement oil pump M295
That's everything I can think of for now.
1) with really good flowing heads, there is no need to overcam this. A large cam is a bandaid in my opinion for less flow from the head.... one reason why square port and rectangular heads have a lot more exhaust duration than intake. So once you have flow, all a big cam is goona do is raise the Powerband while losing low end. This is a street car, coming from experience, you will want low end torque. Especially since you are stock bottom end, I'm assuming you want to shift around 6750-6900? That is peak on a larger cam. I had a 236/238 cam on stock heads, felt great. Seemed like it was a good cam only car. Then I put on heavily ported 227cc 799 heads, and while I gained a little down low, It felt like a turbo kicked in around 4700 rpms. It shouldn't have felt like that, too much cam, too little low speed air flow, I knew the cam was too much now. I would recommend for you no more than 232 intake duration. I'm not a cam guru, so I'll leave it at that. I could have ran a 230/236, gained about 15 tq in the midrange while losing 5hp if that up top. I also wouldn't have that soft spot from 2000 to 4000.
2) ditch the Powerband. The more advanced reads I have seen are that underdriving the accessories really doesn't help much. Unsure if the weight is lighter than stock. I contacted ATI about needing a balancer for my 427 build. The guy I spoke to said that the accessories have become way more efficient than back in the day, and while there are gains to be made, it's not much and the water pump is the biggest drag. So if u did electric, the Power loss from the other accessories will be minimal. The biggest thing he said was the ls stuff needs a heavy balancer to help dampen, and they actually gained 8hp by replacing a lighter pulley with a stock sized pulley and actually it was heavier than stock I believe. The gains he told me were from the better harmonic dampening, which better dampening means your motor will last longer. So he sold me the heavy pulley. May not rev as fast and sound as cool, but will make more power and last longer. Those are a few of my goals.
I usually post too long and people stop reading but hopefully u read it and decide what's best for u
intake duration + exhaust duration ÷ 2
Lsa x 2
duration - Lsa = overlap
one thing to keep in mind tho is where the weight on the balancer is. More centralized will be easier to turn vs weight towards the outer shell which is harder for the motor to turn this helping harmonics I believe. So one could say o 10% underdriv, same weight as stock, best of both worlds. Wrong. The larger pulley with same weight will still have more leverage and thus I believe will control harmonics as well.
All these companies selling underdrive bragging about freeing up horsepower and spinning quicker......but do any of them brag about reducing engine harmonics vs a stock balancer?
If you want mid-high 11's for the CR you might want smaller than 62 cc chambers, and/or thinner head gaskets. Looks like WS6store is making some .45 gaskets, I wish they had those when I did my build.
Also some little thing to consider are trunnion upgrade for the rockers, going for 11/32 pushrods (looks like summit has some now vs the spendy Mantons), ARP head bolts and balancer bolts, new cam retainer plate, new lifter trays, and an 85mm MAF or SD and larger lid to match that FAST you picked up.
I like the 3-4" y-pipe, wish I would have done that too.
For injectors, if you happen to find a deal on some I wouldn't hesitate to go down to 39# unless you plan to spray it in the future.
I know this is a cam thread, if you wait till spring you are welcome to ride in mine and see what you think (226/230-113+2). You already know my thoughts on it, but this is my only cammed car so I can't compare it to others.
For compression I think they only make those heads in 62 and 68cc chambers so will probably have to go with the .041 gaskets. I also have a arp 12 point head balancer bolt ready to go and was planning on the ls2 trays as well.
I will look into a bigger lid and maf. What sizes would you suggest on those? 104 and 85? Unless Carl thinks I should go SD. I would definitely like to see your cammed cars manners this spring.
42# injectors
TBD new clutch
LS2 timing chain
Other than that, i made 428/375 threw a 60e with a yank SS4000 with a SSHT cam.
