Cam recommendations for LS1
Old Mar 12, 2019 | 03:25 AM
RedBirdAuto's Avatar
Default Cam recommendations for LS1
Soo I wanna hear some cam suggestions for my LS1 from a 2002 firebird. Car has tsp long tubes, 3 inch true duals, tune with an m6 and factory rear. Also going to be throwing on some 799/243 heads at the same time so I wanna know what cam would be good to pair with my current mods. Im looking for hopefully 400 wheel while still being okay to drive on the street without the AC stalling the engine lol. Thanks for the help!
Old Mar 12, 2019 | 06:38 AM
Jenson's Avatar
228/232 on 111 is still my favorite little street cam for a setup like yours. Definitely do 243's over the 799 unless you plan on milling the 799's. AC wont stall the engine regardless of cam size if tuned properly.
Old Mar 12, 2019 | 06:40 AM
98CayenneT/A's Avatar
243's and 799's are the same
Old Mar 12, 2019 | 06:54 AM
Jenson's Avatar
I always thought the 799's had more chamber volume. Sorry, I dont pay enough attention to stock heads
Old Mar 12, 2019 | 03:33 PM
Summitracing's Avatar
LS1Tech Sponsor
Pro LS Stage 1 SUM-8715 Ghost cam (222/233 115 + 3 .600/.575) will make the number easily and it's easy to tune. Of course the SUM-8707 Stage 2 (226/238 113 + 3 .600/.600) would be a good time as well and do just fine with a good tune.
__________________
800-230-3030
www.SummitRacing.com
Old Mar 13, 2019 | 02:47 AM
Ive been looking hard at the stage 2 SUM-8707 cam. What would you recommend for valve springs? Also do I need to do anything else mechanically for that cam to work? pushrods, rockers, etc? Running factory 3.42's in the rear if that makes any difference in cam selection, though I'd like to go to a 3.90 or 4.10 in the future.
Old Mar 13, 2019 | 08:00 AM
LS1Tech Sponsor
The more gear you run, the more you can shift power upstairs, but the stage one and two both do well in the midrange where you're spending a lot of time. Both have a 43 abdc closing point...it's the opening point that's changed to get a smoother idle with the Stage 1 Ghost cam. The best spring for that is the TFS-2500287 Dual springs with the Titanium retainers is good if you're doing head work and a Dorman RNB-615-901 intake in the future, but a set of TFS-16918-16 Beehives work just fine for what you're doing at present.
We prefer the factory rocker as it's lighter at the valve, but the trunnions wear over time. It would be a good idea to get the SUM-141560 Bushing style kit and our installer p/n SME-906011. Yes, we have the new thick wall HDR pushrods. We recommend using a pushrod length checker to verify, but you will probably need a set of 11/32 SUM-14197425 7.425 length pushrods. We have the cam installation kit CMB-08-0029 which has the gaskets, seal, o-ring, and LS2 timing chain.
__________________
800-230-3030
Old Mar 14, 2019 | 01:50 AM
Good stuff. thanks for the part recomendations Summit. You guys always got my back haha. One thing though, the part number CMB-08-0029 brings me to a Ford cam package. Typo im assuming somewhere?
Old Mar 14, 2019 | 08:01 AM
LS1Tech Sponsor
Good stuff. thanks for the part recommendations Summit. You guys always got my back haha. One thing though, the part number CMB-08-0029 brings me to a Ford cam package. Typo im assuming somewhere?
Yes apologies,Part number is SUM-09-0029
__________________
800-230-3030
Old Mar 14, 2019 | 09:47 AM
ddnspider's Avatar
Youre probably thinking of 317's. They're an LS6 head with more chamber volume.
Old Mar 14, 2019 | 10:54 AM
mjs1012's Avatar
This. Look into the Streetsweeper HT which is a 228/232 111lsa from Ed Curtis / Flowtech Induction. It's not a popular as other cams on here, but is a hell of a performer.
Old Mar 14, 2019 | 11:06 AM
Right. They came on LQ4 and maybe LQ9 truck engines to cut compression.
Old Mar 15, 2019 | 09:21 AM
Jenson's Avatar
I always do my 228/232's on 110 for street cars just to bring the power in quicker, dont need to rev that high, and they of course sound a little better. The last one I did was an LXL lobe, super quiet, but I need to have Cam motion do my next one just for comparison sake.
