5.3 Newbie
Old Mar 21, 2019 | 04:19 PM
JayAdams91's Avatar
Default 5.3 Newbie
Trying to learn as much as I can about what works and what don’t. I have a 04’ 5.3 and It has 862 heads on the motor now and my question is can I run LS3 heads on this motor? I can get a good deal on them, just don’t know if they’ll work? Don’t know if it’s worth sending these 862 heads to the machine shop to be checked out and resurfaced or buy the fresh LS3 heads. Any advice is appreciated 👍🏻 Thanks everyone.
Old Mar 21, 2019 | 04:36 PM
KCS's Avatar
KCS
Moderator
No, LS3 heads will not work on a 5.3. The bore is too small.
Old Mar 21, 2019 | 04:37 PM
00pooterSS's Avatar
The LS3 heads won't work. They are for a 4" bore or larger motor so the valves will hit the cylinder walls if you install them on a 3.78 bore.
If they did work, they would still be a bad match. They have large ports for larger displacement. They also have large chambers and would drop your compression so low you'd have a really doggy 5.3
You need much smaller heads for a 5.3
Old Mar 21, 2019 | 04:45 PM
JayAdams91's Avatar
Thanks for the info, So are the 862’s worth putting $$$ into?
Old Mar 21, 2019 | 04:56 PM
00pooterSS's Avatar
Depends how much money. At a point it's wiser to buy aftermarket heads but nothing wrong with putting some money into them.
Old Mar 21, 2019 | 05:05 PM
JayAdams91's Avatar
Ok thanks for the info, back to researching and shopping.👍🏻
Old Mar 21, 2019 | 06:12 PM
KCS's Avatar
KCS
Moderator
They’re good heads to go on a 4.8/5.3L shortblock. The chambers are small so they help get the compression up on a dished piston 5.3L. I wouldn’t hesitate to have a valvejob cut for and install 2.00” intake valves. I did the same thing with my 4.8L.
Old Mar 22, 2019 | 09:39 AM
cookseyb's Avatar
I sent my 862's to Texas Speed to get their CNC wok done along with larger valves. going on a 5.3 .040 over size with LS6 intake and their (Texas Speed) truck cam. They look really well done. FYI
Old Mar 22, 2019 | 11:20 AM
JayAdams91's Avatar
If you don’t mind me asking, how much does it cost with shipping to do something like that?
Old Mar 26, 2019 | 06:52 PM
cookseyb's Avatar
It;s on their web site and I live close enough to take my heads down for them to use, which is a difference in price. Also it depends which valve springs,retainers you want. call them, they are nice folks..
