Standard vs high volume oil pump
Old Mar 28, 2019 | 08:53 AM
wyattroa's Avatar
Default Standard vs high volume oil pump
Alright, I am starting to put my engine back together and have the melling standard m295 oil pump to put in it. This is a 6.0L that will have an LSA supercharger on it along with a BTR PDS stage 3 torque cam. I will be running the holley 302-2 oil pan also. Do I need to get a high volume oil pump or should the one I have be fine? I really dont plan on this engine reving past 6500rpm.
Robert
Old Mar 28, 2019 | 10:55 AM
You should be good. High volume is really only needed for engines with looser clearances or those with DOD or VVT.
Old Mar 28, 2019 | 11:41 AM
Darth_V8r's Avatar
Moderator
Agreed. Do high pressure standard volume
Old Mar 28, 2019 | 04:06 PM
wannafbody's Avatar
I think high volume pumps can drain the pan because the oil can't return fast enough.
Old Mar 28, 2019 | 04:09 PM
sjsingle1's Avatar
old wives tale.....not true !!!
Old Mar 28, 2019 | 05:05 PM
wannafbody's Avatar
Pretty sure the LS3 had an issue with drain back even with the standard pump, at least on a road course. I know some guys run an extra quart of oil on track.
Old Mar 28, 2019 | 05:43 PM
sjsingle1's Avatar
i thought of doin a thread on the myth ....but google will tell ya all ya need to know.....quart over is always a good idea even if you dont race
Old Mar 28, 2019 | 06:43 PM
Polyalphaolefin's Avatar
There's a very niche group of engines that would actually benefit from a high volume oil pump. Unless you're spinning the engine 8000+ rpm for long periods of time, or trying to use thin oil with wide clearances, there's no need. It'll just rob power.
Old Mar 28, 2019 | 06:59 PM
99 Black Bird T/A's Avatar
Wouldn't the extra volume of oil a high volume oil pump pushes through the engine help with cooling?
Oil flow does remove a good bit of heat.
Specifically bearings etc.
Old Mar 28, 2019 | 08:18 PM
Common misconception. Oil does not cool the bearings. Less than 3% of all heat in the bearings and crank is from combustion heat. The overwhelming majority of bearing heat is from hydrodynamic friction. The forces of pressure from the crank journals against the oil film. This is why bearing heat, and oil temperature overall, increase with higher viscosity oil. This is also why it's important to run the proper viscosity of oil for the clearance.
A high volume pump also doesn't push oil through the bearings faster. Inside the bearings, ahead of the eccentric path of the crank journal, is an oil wedge. All the pump does is ensure this area is filled with oil. After that, oil flow through and out of the bearing is determine by the rpm and pressure exerted on the oil by the crank journal. A high volume pump is only required when the stock pump can no longer keep up with the demand for that oil wedge. That takes a lot of clearance and rpm to reach that point.
Old Mar 28, 2019 | 08:20 PM
99Silver6.0's Avatar
Is the WS6Store ported LS pump high enough flow I should be worried??
Old Mar 28, 2019 | 09:01 PM
Hydrodynamic friction is a reality, but your percentages are off. I disagree with you here. Oil cools every moving part inside any internal combustion engine, including bearings. I learned this many years ago doing windage tests. We assembled a couple engines (cup stuff) with see-through windows in the valve covers and the oil pan. We photographed the valvetrain with extreme high speed photography (and video) as well as the rotating assembly. Learned a lot about windage in the top of an engine, which 99% of folks never even think about. Also learned even more about windage in the crankcase utilizing different oils, as well as components. At the same time we utilized several sensors throughout the engine to help us determine oil formulations and volume vs. internal cooling of parts, and the sensor locations included main and cam bearings. Trust me here, oil volume and makeup plays a huge role in bearing temps.
Probably the coolest part of this testing for me personally was seeing how many revolutions the roller wheel on the rocker arms turned due to loosing contact with the lash cap at high rpm. Boiled down to rocker flex. We marked the rollers to help us capture data.
We did lots of data tests while I was there for many big cup teams for all kinds of info, from airflow to coolant types. That was the good ole days when cup teams still farmed out engines.
Old Mar 28, 2019 | 09:23 PM
I believe you're misinterpreting your data. I've done the same thing. Trust me, the heat is coming from friction. When you increase ZDDP levels, bearing temp increases due to higher ZDDP having a higher coefficient of friction. When combined ZDDP + Trimer MoDTC, the bearing temps went down from the lower coefficient of friction. Same temperature of oil in the pan, and same viscosity.
Old Mar 28, 2019 | 09:42 PM
Poly & Che70velle That's definitely the best information on oil flow I've seen in a while. I hope both of you will share more thoughts on the topic.
I don't think there's anything to worry about in pumping the pan dry with a ported stock oil pump in any typical application. I ran a Katech ported LS6 and never had any issues for 15 years and 130,000 + miles. WS6 Store is well known for selling quality products.
Old Mar 28, 2019 | 10:29 PM
A ported oil pump does not flow more oil, as the pump itself can only flow so much. The porting benefit is lower friction and resistance to the oil flowing in/out of the pump
Old Mar 29, 2019 | 01:16 AM
sjsingle1's Avatar
interesting read
https://www.mdpi.com/2075-4442/2/2/90/pdf
Old Mar 31, 2019 | 03:11 PM
rednari2's Avatar
It doesn't matter what force is producing the heat. Whether by combustion or friction, the only cooling element the bearings are exposed to is the oil. And I am not discussing oil viscosity or type. The above indicates heat sorces and flow not cooling. That only can come from the oil.
Old Mar 31, 2019 | 03:45 PM
Hydrodynamic friction is the source of the heat, not sliding friction. Therefore you cannot have this discussion without considering viscosity and oil composition.
Higher viscosity oil has a higher coefficient of friction and thus more heat generated.
Synthetic oils have a lower CoF and thus less heat generated.
The lower the hydrodynamic (fluid) friction, the less heat the oil transfers into the bearings. There is no cooling happening there, only control of heat generation and transfer. The only parts of the engine that see a cooling benefit from oil is areas not directly under dynamic oil pressure like rocker fulcrums and cam lobes.
Old Mar 31, 2019 | 07:13 PM
You edited your post, and I missed it. I certainly know what the data we gathered revealed to us. The Cup teams at the time payed us 7 figures to do data testing for them, so we were legit and left no stones unturned. We were one of three companies in the southeast doing this type of work for the big teams.
Ive spoken with many engine builders through the years since, on the topic of bearing heat, with the latest being Tony Mamo. The amount of oil volume reaching the bearings plays a major role in keeping the bearing temps in check. Perhaps we agree to disagree...I do enjoy reading your posts and it’s refreshing to find someone on an automotive forum that knows chemical makeups of lubricants, such as yourself.
Old Mar 31, 2019 | 07:27 PM
That feeling is mutual. I feel we could learn a few things from each other.
