Lq9 Rebuild Or Stroker?
Old Apr 5, 2019 | 04:19 PM
pdxmotorhead's Avatar
My local guy gets about 1800 to assemble a long block,
(Doing the machine work needed / B&B / Good valve job=5 cut with the guides trimmed and flushed )
If you want some porting etc you'll be about 2300.
Thats assuming your providing a reasonably clean block, usable heads and a rotating assembly..
He says about 20 hours average for him to do a high performance assembly.
He cut me a deal one time because the crank I ordered happened to be a sweetheart,
he put it in the machine and it was dead on.. So close he didn't want to touch it.. Saved me about a hundred..
Old Apr 5, 2019 | 04:23 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
If you can piece it together its great but machine shop costs definitely will vary.
Old Jul 17, 2019 | 12:29 PM
RayRayObs956's Avatar
Default 408 stroker 500-550rwhp
Thanks for all the replies guys hadn’t been able to get back in because I needed to reactive my account. So I got a ls3 top end but thinking of just stroking the motor out. You think I can get to 500whp with the l92 top end? If not then around where will I be. Definitely looking into changing back into a cathedral set up looking at TFS 245cc heads with a 50 degree nitrous port and a Holley efi hi rise intake. I have got 90lbs injectors and 4.56 gears so install later
Old Jul 17, 2019 | 12:57 PM
Summitracing's Avatar
LS1Tech Sponsor
With a 408, you could get there with the Pro LS Stage 4 LS3 specific cam. SUM-8711...maybe even the Stage 3. We're getting some really good feedback on it
__________________
800-230-3030
www.SummitRacing.com
Old Jul 17, 2019 | 03:00 PM
500rwhp on a 6.0 with ls3 top end? No. Mid to high 400s yes.
Old Jul 17, 2019 | 03:09 PM
LS1Tech Sponsor
Agreed. I didn't realize the OP had gone that direction yet.
__________________
800-230-3030
Old Jul 17, 2019 | 05:30 PM
Tried to start new post but couldn’t. And hopefully I’ll sell ls3 top end to invest in the new top end I’m looking at. Currently I have the F-35 cam from TSP 235/248 649 lift I believe. Any good 408 rotating assemblies you guys recommend? Appreciate the feed back thanks again
