Lq9 Rebuild Or Stroker?
Ls Swap Longtube Headers, Cold Air Intake, 42 lb injectors
E85 converted so I run corn only. I have stock intake manifold and stock 317s on it. Have a 4l60e with a 3600-3800 3C circle d converter with some 4.11s in the rear. The vehicle is a 1998 Tahoe. It’s a unique project I got going on and at the moment I’m basically stuck now on what to do. Motor had 79k miles on it when I did swap don’t know if info is useful. My motor started knocking day before yesterday after I ran it at the track. Little did I know it was leaking oil. So my engine started making a knocking noise. One of my buddies helped tow it but he says it sounds like I spun a rod bearing. So should I do a stock rebuild? What’s the difference between 370 402 408. I use the truck daily so yeah I like to street race here and there lol. Will see track about twice a month. Mainly street race or cruising. Looking to achieve 500rwhp. I do on the other hand have a Nitrous Express Kit I just got for it. I plan on upgrading to dual springs and a 238/246 cam what do you guys recommend? What’s more budget friendly? I’m not looking to spend $6000 either I’m in the $1900-3800 range Max.
Stock LS1 crank and timing gears: $0
LQ9 block: $500
Machine work to block: $275
Forged pistons for 3.622 stroke: $900
Forged rods: $700
Balance rotating assembly: $250
Valve spring kit: $300
Lunati High RPM lifters: $800
823 cylinder heads: $500
ARP head stud kit: $250
C5R timing chain: $160.00
_________________________
$4635.00
I still need the intake manifold, fuel rails, injectors, camshaft, fuel system and a tune. There's FAST, CHEAP and RELIABLE but you can't have all three.
THIS
And you will still go over budget.
Or find another junkyard 6.0, will cost about the same
You should be able to find a later model 6.0 with the 823 heads already on it though ive seen them for under 2,000 even on ebay with free shipping, then you will already have the better heads and intake.
We can get you set on the parts, machine work is the only variable then.
Our complete rebuild kits are $699. Doesnt include crank rods cam lifters or springs but everything else.
Then youd need a set of 243s ported, and a bigger cam. Port work from tsp starts at 750 and bigger cam means dual springs. So bet on 389 for cam and 289 for springs.
Basically 2120 for all that. Not a bad price though. Then lifters $90 with kit. 2220.
Options are out there but youll need to set you budget higher or hp goals a little lower.
Our gasket kits with head bolts are one of the best priced out there and thats $330 also.
It all adds up even the small stuff. Especially if you cannot do any yourself.
Market place - 4 inch Scat crank for sale $455
Scoggin Dickey had them list for $499 a few months ago.
I’m not trying to argue just to argue, I’m just looking at the minimum price it can be done for, but obviously it can cost way more depending on the parts and how much work you’re willing to do.
