Big sale on Summit Racing Pro Ls cams and valvetrain parts
LS1Tech Sponsor
Received 1,208 Likes
Hello all, this sale is a little different than others. No promo code required at all. Summit brand valvetrain parts including the Pro Ls Cams are 10% off this week! So that means cams starting at $233.99 and thickwall HDR pushrods starting at $144.99!
Thank you for the heads up, got my cam and TFS springset for 500 dollars. Also got 50 bux off for 500 dollar order. Cant beat 500 dollars for the total package with 3 bolt sprocket and bolts.
Hello all, this sale is a little different than others. No promo code required at all. Summit brand valvetrain parts including the Pro Ls Cams or HDR Pushrods are 10% off this week! So that means cams starting at $233.99 and thickwall HDR pushrods starting at $144.99!
LS1Tech Sponsor
Hello, sorry for the confusion. We checked and although the list of parts is long...the HDR pushrods are indeed not on that list. A bit of good news is the $20 of $200 and $50 off $500 and $100 off $1000 just started and may run for a few days. If you run into any errors, please PM us and we'll get it figured out.
LS1Tech Sponsor
Hey there, it's a surprise that just went up yesterday but there's a 20% off $200. So a set of new like the new TFS-2500286P Nanopeened Dual Platimums would come in at about $200 even!
I've gone as quickly as 11.87@115mph at full weight with my basically stock all original bolt on car with just nittos on the stock 16" wheels with the older (date on the cam box is April 2015 haha) 113lsa version btr stage III truck cam. I race at gateway in East STL and I sometimes deliver pizza on the weekends with my 2002 Z28 so it must have truck-like reliability. I'm convinced that my trusty (with proper tuning of course) older model Tci 242932 converter and 3.73 gears (summit girdled original 10-bolt also lol) wouldn't mind the added duration and overlap of the 8714 and your sale was too good for me to pass on, even on a father of two boys budget!!
My only real dilemma caused by your sale is that I'm a guy that only changes one thing at a time on my car and then goes and sees if it's better and the car has reached the point where I think I need to disconnect the front sway bar at the track but I have never done so before. I'm really excited to put the bigger cam in that I just ordered from you guys but I really think I should figure out the front sway bar thing first. What should I do?
LS1Tech Sponsor
Thanks for throwing in a hat too haha, I just saw that. I still think the btr stage III truck is a useful cam as well. I'm hoping it will improve the performance of our 2004 L59 4x4 suburban with GT5 and G80 thankfully picked by the previous owner.
I just went outside and grabbed my new 8714 off my doorstep!!! My new bumpstick came very nicely packaged inside a cusioned bigger box and it looks great! I'm going to have a hard time waiting to install this! Thanks again summit!!!
Dear summit, on my new camshaft card the figures for .006 show the cam installed at a 109 intake center line but the figures for 0.050 have it at a 108 ICL as per the indicated +4 advance.
Is there some kind of asymmetrical thing going on with the cam lobes or are you just trying to tell me that my particular cam had 3.5 degrees of advance ground in it instead of the advertised 4?
LS1Tech Sponsor
You got it. The lobes are asymmetrical, but on top of that all those little tenths of degrees round up differently at .050. So yes we’ve ground 4 degrees of advance into it so you can install dot to.dot and get the valve events we’ve targeted.
Debating between the Ghost cam (SUM-8715) and the Stage 2 cam (SUM-8706). Either cam will be matched with PAC 1219 springs. The build is a 5.3 and the turbo is a 7875. Would it make sense to start with the Stage 2 cam to leave room to grow on power if I ever want to push the engine further.
