395ci LS Build
Old May 14, 2019 | 11:50 AM
Monkey26's Avatar
Default 395ci LS Build
Hi everybody I am new here so thanks for having me. I am here because I am starting a new project and i am wanting to build a 395ci iron block. I got this from the TSP website so it seems like a no brainier with all the sizes listed for you. Has anyone built this engine before? 3.903" bore, 4.125" stroke, 6.125" rods? Any thoughts or suggestions are welcome.
Old May 14, 2019 | 12:27 PM
What are you going to do with it? Which vehicle is it going into? Looks interesting!
Old May 14, 2019 | 03:11 PM
99 Black Bird T/A's Avatar
If the choice is spending ~$4,400 to $4,600 on a TSP 395 with a 3.903 bore or $4,700 to $5,000 on a TSP 408 with a 4.030 bore, I'm going to save the extra $300 to $800 dollars and go with the 4 inch+ bore every time. Bigger tends to breath better in most cases, easier to fit bigger valves etc, more cubes given same stroke crank etc.
Old May 14, 2019 | 03:47 PM
Agreed. I’ll go with bigger bore every chance I get, just for the head choices.
Monkey, you will likely be better off going with a supercharger or turbo, after the dust settles.
Old May 14, 2019 | 05:09 PM
Monkey26's Avatar
Scott your right about the turbo or supercharger being the easier choice. And i thought about going that way. Leave the bottom end stock, new heads, intake and fuel system with a ProCharger. Probably about the same cost in the end.
Old May 14, 2019 | 05:47 PM
00pooterSS's Avatar
All good advice above, plus I'd rather run a 4" crank over a 4.125 in a GM block. 408 sounds better in all directions.
And on the blower being a similar cost, it should be, but you'll have a lot more power and if you pop the bottom end you can grab another used bottom end cheap and slap it in. I've always loved beating on stock bottom ends for that reason.
Old May 14, 2019 | 05:49 PM
Tuskyz28's Avatar
I approve this message.
Old May 14, 2019 | 06:46 PM
Mavn's Avatar
"I MAID THEESE"
Bore > stroke
Old May 14, 2019 | 07:08 PM
Darth_V8r's Avatar
Moderator
You could build a 396 with 4.185 boar and 3.622 stroke. Would rape your all stroke 395 and then steal is lunch money
Old May 14, 2019 | 08:25 PM
This sounds fun!!
Old May 14, 2019 | 09:35 PM
cdubbzz's Avatar
I had a 5.7 based 395ci (3.915 x 4.100) with a 6.100 rod. It made 500/500 w/243's and lasted 20k miles but if I could do that combo over again I'd just do a 4" bore motor......which I later did with a 408 & cathedrals and made 565rwhp. I've got a few old build posts in the dyno or Gen III or IV section, just search my name
Old May 14, 2019 | 09:48 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
What a great plan!
Old May 14, 2019 | 11:30 PM
CattleAc's Avatar
Originally Posted by NAVYBLUE210
What a great plan!
This...
(And not just because I like the raping and stolen lunch money part...)
Old May 15, 2019 | 03:03 PM
Monkey26's Avatar
Thank you . I will check those out.
