Blue Smoke/White Plugs/Milky Oil
Sounds like a bad day. I do not think you are going to avoid a tear down.
This would be a stretch, but MAYBE waterpump leak and front cover leaking so coolant gets into oil that way? But I kind of doubt it.
I suspect you have a crack at the valve seal that is reaching the coolant jacket.
Moderator
Received 1,838 Likes
If you are brave -- loosen your six K member bolts about a half inch or so to lower the cradle. Will give you some more room to work around the studs
That oil has ~50 miles on it. I’m losing coolant, and the heads had milkshake pooling around the guides when I pulled valve covers on both sides, and milkshake in the crank case when I drained it - the light in the pic is difficult to analyze. I’m also losing coolant when it runs.
