Intermittent P0336/ constant P0300
Who knows how it happens but I have seen several sensors seep fluid through to the connector.
I've had a fuel injector do that and send fuel up the wiring and fill up the PCM with fuel
I've seen a coolant temp sensor fill up a PCM with coolant from the same thing. The internal seals go bad and sends fluid into the connector, the connector is sealed and if the sensor goes into fluid that is pressurized it will send fluid up the wiring, it's crazy ****.
You won't have that issue though, just clean it up and put another new sensor in. Or put the old one back in, I'm a tech and I've never seen one of the OEM sensors fail
Connections get slightly corroded, to the point you may not be able to even see it in those tiny pins, from sitting in one spot for years. Unplugging and replugging actually scrapes the pins a little and restores the connection.
