Intermittent P0336/ constant P0300
**So, P0336 has popped up recently but not all the time. I have replaced crank sensor, pigtail, plugs and wires. I also replaced 3 coils that showed misfires but havent hooked it back up to check to see if those are gone. I ran well for a while after the coil swap. This is killing me! Worst case i think would be a bad/damaged reluctor wheel. Can a bad over rev cause reluctor wheel damage? Any help is appreicated.**
**UPDATE**
So I finally got a chance to do the compression test. Ran the test twice on each cylinder. Took the car for a drive and let it come up to operating temperature before testing. Just did the dry test. Here are the results. What should I do next??
CYL PSI
1 190-195
2 195-200
3 190
4 200
5 190
6 200
7 190-195
8 195-200
How far did you rev out 3rd before going into 2nd? If you red lined 3rd then hit 2nd there's a good chance a valve touched.
If you were cruising you're probably fine.
after you clear codes.....
if you make it 25 miles you have a 75% chance of code coming on, basically make it over the 40 mile hump is my goal. after 40 miles id say 25% chance your code comes back. make it 75 miles you have 10% chance of a code, after 100 miles you are basically in the clear. no science behind it other than i believe most monitors are running by 20 miles and all should be running by 40.
so basically go put some miles on it and report back, what shifter you running
Shifter is Hurst Billet Plus.
LS1 block 3.903 bore
4.00" Callies Compstar crank
6.125" Callies forged rods
Weisco -3cc forged pistons
LS7 lifters
233/244 .629/.615 111+3 Pat G Cam
Comp Cams 7.4 pushrods
LS2 timing chain
Melling HP oil pump
TSP 2.5 799 Ported Heads 2.02/1.57 valves
.660 PAC dual valvespring, titanium retainers
LS6 Valley cover
Powerbond 25% underdrive crank pulley
FAST 92mm intake/throttle body
FIC 50# hr fuel injectors
