Blowed up the boosted 370ci!!!
Just for ***** I went out adjusted my tune to mid 9's AF and ran it up and down the road a few dozen times under boost... zero knock. So 10-10.5 certainly won't hurt anything and I haven't seen it hurt anything in the past.
The interesting thing about this discussion is the simple fact that you aren’t logging actual knock. You are seeing the resultant retard the ecu applies to the timing after is sees the knock. Remember the knock has already happened. Retard is the result. And the retardant of course is the result of more than a few parameters in the tune you can change.
Back to the Hemis. In this setup, we can view the actual knock sensor volts in real time. Pretty interesting. You see the spike, then see the retard.
We run them 11:1 on pump fuel when boosted. No more than 7-8 psi if stock bottom end. The mighty Hemis are fragile! Ha!
We pretty much gave up on pump ****. Waste of time if serious about going fast with any sort of reliability
Back to the original story. Two bent rod bolts and the rod cap in the pan? I’m wondering if that rod got missed when torquing?
Ron
Im been thinkin on this lately. I think the block had a crack in tht cylinder, tht eventually busted and basicly bent/broke the rod etc.
Truck was having some issues were if i made 2 pulls kinda back to back it would get pretty hot. It would eventually cool right off when cruising. Never got hot at idle, in traffic etc. Just after 2 back to back hits.
This is why i think it might have had a hair line crack tht could have busted! Thoughts?
U can also see where the rod dug into the crank journal. This is what broke the cap/rod bolts. It took a hell of a hit. And for the rod to be twisted and wrinkled like it was, it does seem possible.
