Lr4 4.8 vs Lm7 visuals?
If they do not test for output, a good way to gain power in that 5.3 would be a stock 2003ish LQ4 /LQ9 cam. They idle like stock, retain almost all the OEM low-end torque of the 5.3 and gain close to 40 HP at redline. The later LQ4 and LQ9 engines have the same cam GM put into the 2001+ LS1 engines.
The only visual difference in a 4.8 and 5.3 would be the crank casting number, connecting rod number, and in some applications a dished piston rather than a flat top. But some 5.3s also have flat tops.
The only Gen III 5.3's with flat tops are if they have 243/799 heads.
https://www.onallcylinders.com/2018/...ads-cam-specs/
