Lr4 4.8 vs Lm7 visuals?
But then I found out that the 1999 Lr4 only had 255hp.?
Is there any way to tell if its a 4.8 or a 5.3 just looking at the engine?
And you know if there was or what car in 1999 had the Lr4 with 4l60e tranny?
Thanks!
lm7 does have a dished piston instead of a flattop but from the outside there’s no way to tell
Ok =) well the 1999 4.8 was the Only one with 255hp. After that it had 270-280 if I can remember correctly and thats more then a 20% increse from stock engine so wont work. =/ But I guess and hope he cant see the block numbers lol
The power rating difference is weird because there is NO difference in parts between higher or lower rated versions. Same cam, heads, etc.
Do they dyno you car to check the power output? im sure there are MANY ways to get around that. .. throttle stop? load a crappy tune?
or do you just tel them what engine it is and they go by that?
No dyno thankfully hehe. I guess they would like to have some sort of block numbers or maybe a donor vin but im hoping I can get around it somehow lol
If the ECM has programming from a vehicle with a 5.3 Vin, which is
accessed through the OBD2 port, it might raise suspicions. Also, headers
and a cold air intake does not reinforce the premise that the engine is stock.
Why so many rules? if you can only add 20% over stock power, can you do weight reduction?
