rocker arm replacement
Old Jun 14, 2019 | 12:38 PM
patSS/00's Avatar
I've also had it take minutes for lifters to pump up, after changing pushrods. When you rotate the engine by hand or release pressure on a lifter by removing the rocker then put it back, there's no oil pressure, so the oil can drain out of the lifter, not the same as just shutting off the engine. At least that's my guess.
Old Jun 15, 2019 | 12:55 AM
1FastBrick's Avatar
Originally Posted by frisco88
i bought these rockers from michigan motorsports and they're supposed to b direct replacements.
what exactly do you mean by bottom out and did you torque to 22lbs.thanks for the info.
They are known to sell the "enginetech" brand stock replacement. These are known to have issues and some of the arms have failed. I know of one hear locally in town. When I asked him where the rockers came from, He named the same place... They also failed in the same fashion.
https://ls1tech.com/forums/generatio...ke-before.html
https://ls1tech.com/forums/generatio...ocker-arm.html
Old Jun 18, 2019 | 09:01 PM
frisco88's Avatar
Default success
i removed the valve covers and torqued everything down.i did find 1 rocker that i guess i missed when torquing them down the 1st time(my bad) and 1 other that wasnt loose but the torque wrench cicked a couple of times .anyways thanks to everybody for their help and thanks colorado for setting me straight on how to tighten them.it started up no clatter.
Old Jun 19, 2019 | 10:32 AM
Ls7colorado's Avatar
Awesome
