Unknown Camshaft. Help!!!
Old Jun 13, 2019 | 01:50 AM
99 Firechicken's Avatar
Default Unknown Camshaft. Help!!!
I have this cam in my 99 trans am and I have no idea what the brand or specs are. I finally had the opportunity to take a look during a clutch swap, but I have no idea what any of these numbers mean. Does anyone know what kind of cam this is? Or what these numbers mean?
Old Jun 13, 2019 | 06:29 AM
KCS's Avatar
KCS
Moderator
Thats a Comp camshaft. The top row is the intake/exhaust lobe part numbers. The second row is hydraulic roller (HR) with a 116 LSA ground with 2 degrees of advance (+2).
Old Jun 13, 2019 | 11:56 AM
Thanks for the help! I spoke with comp cams tech support and was able to get all the info on the cam
Old Jun 13, 2019 | 12:05 PM
Ls7colorado's Avatar
So, for everyone's curiosity, what was the information?
Old Jun 13, 2019 | 12:14 PM
Apparently the cam is a custom grind 226/230 .585/592 with a 116+2 lsa and xer lobes. I've been driving on this cam for 3 years not knowing the specs and being asked multiple time about it but finally today I know.
Old Jun 13, 2019 | 03:32 PM
SLP IROC-Z's Avatar
Idle vid?
Old Jun 13, 2019 | 05:10 PM
wannafbody's Avatar
Should be a good street cam
Old Jun 14, 2019 | 11:11 AM
stockA4's Avatar
Originally Posted by SLP IROC-Z
Idle vid?
What heads do you have on there with that wide lsa and how does it drive? I'm running a 226/230 112+4 with stock 241 heads and it's pretty awesome
Old Jun 17, 2019 | 08:04 PM
I put some stock 243 heads on it a year ago. It made 374whp and 350wtq pulling to 6600 on a heart breaker mustang dyno. It drives so well on the street, I can cruise at 1k rpm in 6th gear with no bucking
Old Jun 18, 2019 | 09:52 AM
Darth_V8r's Avatar
Moderator
There was an old EPS shelf grind pretty close to those specs too. Should have great midrange grunt.
