First Cam Swap
Old Jun 24, 2019 | 02:37 AM
fbombsilverado's Avatar
Default First Cam Swap
I've got a 01 Silverado, LM4 out of a Rainier and I was looking at putting a Howards Rattler Cam in the truck. Since this is my first cam swap, I was wondering if I need to install a stall as well or would the stock converter work. If not, could someone suggest a decent lopey cam that would work with the stock stall. Thanks in advance.
Old Jun 24, 2019 | 03:16 AM
98CayenneT/A's Avatar
What is the truck going to be used for?
The stock converter may work with that cam but I wouldn't.
At the very least, if you're looking for budget, you can run a trail blazer i6 converter which has a stall speed of 2800 rpms and can be picked up at your local parts store for a couple hundred dollars.
Old Jun 24, 2019 | 03:17 AM
Daily driven, just looking for a little power gain and a better sound.
Old Jun 24, 2019 | 06:30 AM
Ls7colorado's Avatar
my suggestion
https://www.summitracing.com/parts/sum-8701/overview/
That would be about the biggest i would consider with the stock converter.
Here is an Idle video
no matter what you go with your gonna need new valvesprings, just remember that.
Old Jun 24, 2019 | 10:21 AM
trilkb's Avatar
I got my GM55 converter from advance auto for under $200, probably under $150 with coupon codes, just gave them my trans am converter back as a core. For a daily driver It may work ok, but in my trans am I feel ZERO difference over stock. I dont even think it helps with "loosening up" things for a cam to idle a bit better but my mail order tune probably isnt the best either.
Id go ws6store hotcam (because I did) comes with springs to match, should work well.
Old Jun 24, 2019 | 11:57 AM
A lot of times the “parts store” converters are just a universal stall.
i would get one off eBay or junkyard that came out of a trailblazer
Old Jun 24, 2019 | 05:31 PM
The converter in the truck is out of a 5.3 Rainier, would that be the same as the i6 trailblazer?
Old Jun 24, 2019 | 05:32 PM
what cam is that?
Old Jun 24, 2019 | 07:34 PM
There is a direct link to that cam above, I’m pretty sure the 5.3 rainier torque converter will not be the same stall speed as the 4.2
Old Jun 24, 2019 | 08:07 PM
GM92 is the code, I have found out it is a 2200-2500 stall
Old Jun 25, 2019 | 07:26 AM
trilkb's Avatar
According to oreilly the gm92 is the v8 converter, the gm55 is the i6 converter.
Old Jun 25, 2019 | 07:40 AM
SLP IROC-Z's Avatar
My friends saab 9-7 with a 5.3 stock would stall to 3000
Old Jun 28, 2019 | 11:24 AM
kott0n's Avatar
My LM4 2004 Rainier also flahses to 3k before moving.
