PRC 225s cam selection
Old Jul 22, 2019 | 02:14 AM
  #41
TBSOELS1's Avatar
Originally Posted by Bspeck82
If you think too much about it you will go crazy. If you want to learn about cam tech and about lobes, lift, intensity, acceleration and jerk there is plenty of info online as well as a great podcast with Billy godbold on The power and speed podcast. But when it comes down to it, just be honest to the tech on the phone with your goals, get the cam they say works for you and move on. Just my opinion.
http://readingtondigital.libsyn.com/...d-of-comp-cams
Yea I think once BTR specs the next cam I'm just going to roll with it. I'm sure I will be plenty happy with the way it turns out.
Old Jul 22, 2019 | 05:44 AM
  #42
Tuskyz28's Avatar
BTR spec my cam.... it hauls ***
Old Jul 22, 2019 | 07:43 AM
  #43
Jtm2085's Avatar
Dont let this fool fool you. First off there is no sense in a big cam unless you are going to turn the rpm the big cam wants to turn and you need a valvetrain to handle it. If the heads, gears, valvetrain. Stall/clutch etc dont match then you have a car that drives poorly, sounds mean and is a dog at the strip. Build smart. Dont build for bench racing/peak power. And no, you cant tune out valve overlap, a mechanical function of the cam lobes.
I see both sides to this. But you can absolutely have a good size cam and good drivability. I suppose both of those things are relative though. I dailey'd my car for a long time with the btr 4. It idled well with the AC blowing cold etc. Yea it had some lope to it but it is a hot rod and I expected that. The car performed well for what it was too. Made 460 on a dyno jet and trapped 124
Old Jul 22, 2019 | 07:49 AM
  #44
TBSOELS1's Avatar
Whats your setup?
Old Jul 22, 2019 | 01:50 PM
  #45
SLP IROC-Z's Avatar
Gotta match the clutch to your cam, dont forget
Old Jul 22, 2019 | 02:04 PM
  #46
TBSOELS1's Avatar
I sent Monster my custom clutch sheet, waiting to hear back....🙃
Old Jul 22, 2019 | 03:09 PM
  #47
YOKED's Avatar
Damn near fell out of my chair when I read that too...
Old Jul 22, 2019 | 03:34 PM
  #48
Tuskyz28's Avatar
Whats your setup?
LS2 with LS3 heads and intake. Cam is 229/244 duration. Kooks headers and Kooks true dual exhaust.
Old Jul 23, 2019 | 06:45 AM
  #49
Mavn's Avatar
"I MAID THEESE"
Originally Posted by tuskyz28
btr spec my cam.... It hauls ***
Old Jul 25, 2019 | 02:01 AM
  #50
TBSOELS1's Avatar
Email i received back from BTR - “I mean the stg 4 ls1 cam would work or if you wanted a little less aggressive , we could do a custom and go to like a
231-243 112+3”
Old Jul 25, 2019 | 08:22 AM
  #51
Bspeck82's Avatar
The 231 cam wouldn't be bad at all, I'd run that one.
Old Jul 25, 2019 | 08:43 AM
  #52
TBSOELS1's Avatar
Same duration as the last one with a little less overlap
Old Jul 25, 2019 | 11:42 AM
  #53
hiltsy855's Avatar
Regarding "drivability" - it depends on your tolerance and driving technique as well. A cam with 13 deg. of overlap is not going to drive like stock in a 346. One guy might say "it drives great" but he never cruises below 2500.
Old Jul 25, 2019 | 10:29 PM
  #54
wannafbody's Avatar
That's easy.
Stage 1 cam, stage 1 clutch
Stage 2 cam, stage 2 clutch
Stage 3 cam, dual clutch
Old Jul 28, 2019 | 04:25 AM
  #55
TBSOELS1's Avatar
So its down to these 2 cams -
Custom BTR - 231/243 112+3
or the cam i have laying around
Tick SNS 2 - 227/235 110+3
Old Jul 28, 2019 | 01:48 PM
  #56
LS_ELKO41's Avatar
Some guy put down close to the 450rwhp with the PRC 225s and the Tick cam. Not sure what else he had on his car and I know it's just a number, but Ive heard good things about torque with the SNS2 cam. That's the one I would do out of the 2 if it were my build. Apparently the TSP Torquer V4 is similar to the SNS 2.
https://ls1tech.com/forums/generatio...eads-come.html
Old Jul 28, 2019 | 03:44 PM
  #57
jdwtx85's Avatar
Just curious what cam specs you all would go with on a typical hci ls1 6 spd with PRC 225s 62cc, ported FAST 92/92 and full exhaust. Car is basically just a weekend warrior with track time once or twice a year. I sent out a custom cam sheet to BTR and still waiting to hear back. Want something that will work well with the PRC 225s. Curious on your alls thoughts and how they will compare to BTRs recommendation.
Google prc 225 with tick polluter cam!!!!!!!
I'd go tad smaller like the sns stage 3 torquemax from tick Jr somthing along those lines with the prc 225s and a 346ci
The 62cc heads and ls1 should be like 10.8 comp I could be wrong. Use a thinner gasket to get to 11.1 and have pat g or ed curtis spec you a cam!!!!!!!!!!!!!!!
Old Jul 28, 2019 | 03:56 PM
  #58
jdwtx85's Avatar
We just build a iron 6.0 .030" over with same heads and vengeance ported fast 92 and tick polluter v3 cam.
In a c5z with 342s drives great 18* of overlap I think.
BUCKING IS ALL IN THE TUNE!!!!!
it put down 494 thru stock maf.
I bet a ls1 could make 460-70 with these heads and good combo
Old Jul 28, 2019 | 04:44 PM
  #59
LS_ELKO41's Avatar
Well I guess I'm going to reconsider a smaller overlap cam then since a lot of people are recommending bigger. I have a good tuner so the car should drive good and make more power this way. I wouldn't mind 470+ to the wheels.
Old Jul 28, 2019 | 05:17 PM
  #60
Bspeck82's Avatar
The tick cam will make more mid range and low end torque and won't carry power as far as the BTR cam. Btr cam will make more on the top end and result it bigger dyno numbers. Both will drive and sound about the same.
