LM7 5.3 Build
what Hp level/how fast you want it to be would help
And the most important thing of all..... Whats the budget? I know you said you dont want it to be a "budget build" but you also said you just now have become financially able to make this happen..
So Im gonna assume the budget is still fairly low????
With that said, the STOCK crank will handle 1000rwhp...... and with a turbo application a stroker isnt going to be as a big a deal as it would with a N/A setup
also 3.905 is pretty much the max bore most have done on a 4.8/5.3 block why do you need to take it THAT far?
I would price out the cost of machine work and new pistons/rods vs the cost of just buying a complete Gen 4 or late Gen 3 5.3, as those will hit your goal on a stock long block.
You can even pick up a complete L33 now for under $1500 (Shipped to you) witch would be the route I would take Those are aluminum block, have Gen4 rods, 243 heads, and hair more compression.
I would Gap the rings, Valvesprings, ls9 cam (or better) and throw some arp head studs if you want.
With good fuel and tune you will hit 700rwhp reliably.
If you want to go further just take your pick of forged rods/pistons and crank up the boost! lol
