New to the ls world
Thats why im asking what number your looking to run, being a DRAG truck I would assume you would want to go all out?
If its a complete budget build then a small cam will still perform ok with that 3200
What is your rear gear?
They leave a LOT on the table for an N/A setup with the bad lobe designs and lazy ramp rates.
Even soft lobes from other manufactures look harsh compared to those cams.
If your 04 5.3 has gen 4 rods/pistons, then you can rev it to 7600-7800 regularly without any issues from the bottom end.
You're going to need a real camshaft for that, not one that you bought because it was the cheapest option.
Either way you will want some good pushrods, double springs with Titanium retainers, a good trunioun upgrade and a good set of lifters to be spinning that high witch is all $$$$
Summit has some excellent new cams out for great price
My last 2 04 engines had gen 4 rods and pistons.
Either way, as long as the gen 4 rods are in there, you're set. I don't believe there was ever a discrepancy in the rod bolts regardless of pressed/floating pin.
Summit, Howards, Cam Motion are all I use for LS cams anymore, depending on the situation.
Of course you can go bigger and badder since its a drag truck but that cam would easily get you into the 12's actually you would probably be well into the 11's since it will be setup for drag.
That cam will still be ok with some cheaper Ls7 lifters and a $100 set of pushrods. I would still do a rocker trunion upgrade though.
Even if you have Gen3 rods I wouldnt worry much
I used a very similar cam in a stock 5.3 last year with long tubes and valvetrain and it made over 430 horsepower on the engine dyno.
That was stock truck intake, stock heads, pump gas. I could have made 450 with a little more timing up top, but I kept the timing curve fairly flat.
470-500 would have been doable with a gen 4 truck intake, flat top pistons, and some timing
If you happen to have gen 3 rods i would just look for a set of Gen4 4.8 pistons and rods or some new flat tops and a used set of gen4 rods while you got it apart.
if you dont wanna tear into the bottom end I would still suggest the Newer intake, they are the best bang for the buck
That cam is big for a 5.3 for sure though. You're gonna want at least a 4000 stall.
Don't be concerned about going big on the stall. The most common street stall size for the last 20 years in LS cars is a 3600. And that's what guys use on the street. I had a 3800 in my daily driver that got driven 500-800 miles a week on average.
I'd probably go with a 4400 in that truck since it's a drag truck.
If that truck is gutted and light, I wouldn't be surprised if you get into the 10's with that cam, a big stall, and decent suspension. Grab some caltracs for the truck too if you don't already have some sort of traction bar in it.
