LS1 timing chain sprocket test video
I agree, the test was not intended to prove anything.
Interpreting the video may be subjective but valid regardless.
My feeling is it's too weak.
Thanks stockA4
I don't think I'm game to go past 6500 as I have a 99 LS1 they had the weaker rod bolts.
Cam tension....If it's as tight as a banjo string your probably going to have a problem regardless, If you can deflect it 1/8" you're good to go with either block material. Your always going to have some deflection as soon as the chain and gears break in. As far as aluminum block growth is concerned I've always been told it was twice that of an iron block but when you're measuring in thousandths of an inch its still not enough to be concerned about when it comes to timing chain tension. I try to use RollMaster/IWIS chains on any engine because they have proven to be a quality part.
If you line bore you can use this guide for the proper gear/chain combination. Rollmaster:How to Determine Tunnel Bore Sizes
"One gear or the other is offset and it's most likely the cam gear"
Do you think cam or crankshaft bearing wear or wide tolerances could cause it to tighten and loosen when turned rather than cam gear being offset?
Regards Tim
The same can be done with the crank snout by and the cam if you remove the gears.
With that said, you're hitting the cam gear and breaking it where it's thinnest. The cam gear is not meant to sustain shock loads along that axis. It's designed to sustain loads along a perpendicular axis.
The fact is that these OEM gears have been used in pretty rigorous applications, with dual springs and high RPM, and the gear itself almost never breaks. The aftermarket sets have advantages in being adjustable and providing an extra row of chain, but that's about it.
Thanks stockA4
The 8713 only has 1 degree more intake duration than my current cam, the 8714 has a little more overlap too although I might end up advancing it 4 to 6 degrees when installing it, the overlap will still give it a nicer idle than my current cam even if duration ends up exactly same, not sure which way to go yet. My main goal was to get a nicer idle and hold on to peak power longer for better quarter times my BTR 219/224+3 113 truck cam in my LS1 drops hp like a stone after 5900 rpm and hits it's peak power at 5650 rpm ( a mere 250rpm window) its not unusual to see cams hold on to power for 1000 rpm past peak or more. This is what I'm wanting.
If you did a test on the glass with your car with a hammer, it would have the same merit this test did. Neither item sees shock loads, nor was it designed to. If things not standing up to a hammer bothers you, you're gonna be changing a LOT of parts on the car.
One thing that will shatter the cam gear or oil pump gear is harmonic vibrations, so the billet set may stand up to that better, but you'll have other parts of the engine hanging out of the oil pan most likely if the vibrations are that bad, you're timing chain may be re usable though.
Timing gear on the other hand can be made out of a billet of Heat treated carbon steel with both the properties of higher impact resistance and high wear resistance as they almost always are when aftermarket dual or single row billets are used for little additional cost to deal with the additional stress loads. So there is no compromise needed.
Sintered powdered metal often fails in some engines when it is used for the oil drive gear along the centreline of the keyway and also the internal parts of the common M295HV oil pump are sintered powdered metal (& many others) and can and do break if not installed centred correctly with high rpm use (are these subject to impact?). Even if the camshaft sprocket is made from powdered metal or ductile iron the crankshaft timing sprocket is usually made from HC heat treated steel as it is recognised this area needs the extra strength and possibly extra wear resistance also, it surprises me then that the pump drive and internal part of most oil pumps are often not made of the same HC material hence they break more often.
Brittleness and strength are related (ie, if it is brittle it's likely to have other non desirable characteristics in some applications)
https://www.sciencedirect.com/topics/materials-science/brittleness
Oil pump
https://ls1tech.com/forums/generation-iv-internal-engine/1641885-wtf-how-do-you-break-oil-pump.html
There's a shimming process where you take the front cover off and center the housing using shims between the housing and the rotor. It's fairly well known about around here.
