Best springs for gt2-3 cam.
Hello everyone,
I'm looking in to purchasing a gt2-3 cam and was wondering what springs would be best used for it. I was planning purchasing the kit below but figured i would ask people more knowledgeable than I.
https://www.summitracing.com/parts/tfs-2500286p
It's Overkill but it'll work. If memory serves me that cam is in the .58x range of lift so .600 lift springs would be fine. I ran that cam over a decade ago and loved it. Pulled to 6800 and idled and drove like stock. That said, there are cams out now that will drive just as nice with a good tune and make more power.
I am open to any and all cam suggestions. Just have to work with stock heads and manifolds. I only have this limitation due to being poor and rebuilding the engine. Figure I can add a small cam for power.
Any cam will require a tune, need to know the rest of your setup to choose a cam specs. I understand poor hotroding so summit pro LS grind and ls6 springs is what you want to be looking at, they are the best bang for the buck in the business
