patriot heads are they worth it???
The reason that I ask is that I would like a 72cc combustion chamber that is correct for a 3.9" bore instead of correct for a 4" bore.
i did all my mods myself except rebuild tranny and saved as ton i am sure those vette guys on the other board spend double what i did
I'd like to know you plan on "doing a few things different." And if I'm off work/available I'm definitely willing to lend a hand, as always.
Before swap 385rwhp dyno tuned run then 409rwhp dyno tuned run with AFR's. That showed me the potential of these heads. BTW I had LT1 AFR heads and was dissapointed, but LS1's are a different ballgame. Every company has a flop. Otherwise we wouldn't own any American car
Special #2 CNC Ported LS6 Heads
Once in a lifetime opportunity! Earlier this year we bought truckloads of bare LS6 cylinder heads for our engine customers and for our own R&D programs. What does this mean to you? A one-time special price on bare LS6 CNC ported heads. And here is the really cool part, we have not milled anything off of the deck surface so you can set the chamber size to your specification. A big plus for you LS1 guys who are trying to kill a little compression ratio or you just simply need a larger chamber for those big cubic inches.
These are fully CNC-ported new LS6 castings (243). The seat area is hand finished and they have a high performance valve-job. Wash and assemble! The valve seats are prepared for the stock LS1 valve sizes of 2.000” and 1.550” --- another big plus, because you can take your stock heads and just switch the components for bolt-on horsepower. No need to buy new valves, just match your valve springs to the camshaft, decide what chamber size you require, mill if necessary, lap the valves and assemble! Customers have reported a 30rwhp gain on stock ZO6’s with absolutely no other changes.
The combustion chambers are approximately 70cc with the stock GM valves. Larger valves can be installed, of course you will need to have the seats cut for the increased diameter, though we have not seen any gain on the stock bore with the combustion chamber remaining in this configuration when larger valves are installed.
For an additional $92.00, you can send us your valve train components and we will back-cut the intakes, lap the valves, set the spring heights, and assemble the heads for you. Completely painless! This price is for the stock diameter valves only and does not include any additional components or labor that might be required for proper assembly, i.e.; valve seals, shims, etc. Think about it – no core charge, new LS6 heads, CNC ported, use your stock valves --- it’s a no brainer! Don’t wait too long, ‘cause when their gone – they are long gone!
Flow Figures 0.100 0.200 0.300 0.400 0.500 0.550 0.600
Intake 66 140 210 255 291 304 307
Exhaust 55 112 163 213 218 222 225
SF1020 - 28”H2O, stock valve size 2.00/1.550, SDPC back-cut intake valve.
The 72cc chamber is the O.E. chamber. These are designed for the big bore motors. The largest chamber we have for the 3.9" bore is the 68cc chamber.
Of course, you can use the 72cc head with no problems. We have had customers with forced inductions use these on the small bore motors with great results!
