Initial tune and where to go from here?
5.3 w/ stock (rotating assembly, 862 heads, injectors)
-Sikky mount kit, pan, 1 7/8 long tube headers
-ARP head bolts, rod bolts, crank bolt
-Texas Speed cam (pn 25-TSP223226R6111)
-Texas Speed pushrods (stock length)
-Dual timing chain set
-Melling oil pump
-Ls7 lifters
-Dual valve springs
-Titanium retainers
-ATI Super Damper
-Fast 90 intake
-Ported throttle body w/ Fast adapter plate
-Summit fuel rails
-Monster 18lb flywheel and clutch
-Melling oil pump
-Ls7 lifters
-Dual valve springs
-Titanium retainers
-ATI Super Damper
-Fast 90 intake
That leaves you with a stock 5.3 with:
-Long tubes
-223/226 111 LSA cam (guessing from the part number)
-Fast 90 with ported throttle body.
-Lightweight flywheel
Its probably around 425 crank HP.
That translates to 360whp on a dynojet (15% loss)
And then to 318whp on a mustang dyno (additional 12% loss).
I'd say that's right in line.
FYI, I did a 5.3 with a 222/225 112 LSA cam, single beehives, 1 3/4" long tubes, stock everything else, and a lot of time invested in the tune.
It did almost identical numbers on the engine dyno and then the chassis dyno but through a 4L60e and a locked converter.
-Long tubes
While I appreciate the breakdown and additional perspective, I was more looking for next step ideas. I am looking into heads and injectors but wanted some insight on choosing the best bang for my buck setup.
You can score a set for probably $100 shipped and they'll give you roughly a full point increase in compression.
That cam is also pretty mild. You have to choose between driving manners and power at some point. Every cam I've used that is similar is size was extremely nice to drive in a 5.3.
You can keep the cam you have and have your stock heads ported, or go to a larger camshaft for similar gains with your stock heads, etc (assuming there is a budget).
I'd just drive it and enjoy it. Mustang dynos can vary and usually are quite a bit lower than a DynoJet. Might be a 360rwhp DynoJet number, which is about right.
You can always add a 100-150 shot of nitrous on top if you need more later without changing the setup or breaking the bank.
