C5 engine decisions
Old Oct 18, 2019 | 02:21 AM
NSFW's Avatar
While a 102mm throttle body would be ideal with a Fast 102 manifold, 102mm DBW throttle bodies are kinda hit-and-miss. I've got a NW 102 that won't open past about 20% that I still need to sort out, and I'm using an LS2 TB with my Fast 102 in the meantime. That plus stock heads milled to 60 or 61cc (I forgot...) plus 2" headers and a 3" x-pipe and Torquer V2 got me 475whp on a dynojet, so I support your plan.
The Fast 102 plenum is a bit larger than the Fast 92 plenum, so there's still some advantage even without a 102mm throttle body. But I suspect I could get a few more horses if I can get a 102 TB that works right. (My "plan B" is to arrange two stock TBs in parallel.)
Tuned to idle at 850 RPM, it actually sounds pretty close to stock. A little rough, but it's subtle. Bringing the idle down to 700 RPM might bring out some chop, but I haven't tried.
The V2 is probably kinda small for a 383 though. If you go that route, you could go a little bit bigger on the cam to get more power without any drawbacks.
Old Oct 18, 2019 | 06:32 AM
Daniel Kinsler's Avatar
Well so far the fine folks at Texas Speed have told me the V2 is a great choice for a 383. I did go ahead and purchase a FAST but I got the 92mm instead. What is the call on using an LS2 fuel rail with LS1 injectors? Also I am trying to figure out transmissions and differential gearing. I am thinking a Z06 MN12 trans with either the OE 3:42 or move to a 3:73. Maybe even a 3:90. Yalls input would be appreciated
Old Oct 18, 2019 | 07:58 AM
Bob570's Avatar
I have the Torquer V2 in my SBE LS1, I will say it's a great cam for canyon carving. As far as the MN6 vs MN12, it's my opinion that the MN6 is superior. The shorter gearing in 3rd gear paired with the same ratio 4th gear causes a huge drop in RPM between shifts. If you want more aggressive gearing I would keep the MN6 and get a more aggressive rear end. The only down side is that it will raise RPM in 6th gear on the highway.
Old Oct 18, 2019 | 10:23 AM
Thanks Bob, my biggest drive towards it is when I had my 14’ Camaro 1LE that had the close ratio TR6060 w/ 3:91 gears. It accelerated so well and stayed in the power band
Old Oct 18, 2019 | 02:05 PM
00pooterSS's Avatar
If I did the rear gears I would go 3.90
And I think the cam will do nicely personally
The LS1 injector is taller than the LS2 injector. The LS2 injector is also fatter at the bottom. So they aren't interchangeable. There are adapters to make them work out if you have to adapt one style to another though.
Old Oct 18, 2019 | 04:02 PM
Good lord, guess Ill run my LS1 fuel rail for now and the 42lb injectors I have.
Old Oct 18, 2019 | 05:12 PM
00pooterSS's Avatar
That's another wonderful thing about the 92mm vs the 102. You can slap your LS1 rail and injector on the 92 but the 102 has injector bosses for the larger diameter injector bottom so you have to figure that part out and also requires new rails since the OE ones wont cross over the top of it and go down far enough. The FAST 102 comes with fat orings to stick on skinny injectors to convert the skinny injector to be used in the larger diameter hole that is in the 102mm intake but man I've had a ton of issues with the 102 and injector leaks that took a while to straighten out. The 92 is so much more plug and play, you just slap it on and go. The 102 ughh.
I did a 102 on a friends car and he had 60 lb injectors for it. For some reason they injectors were the right diameter but like .010" too short and they kept popping out of the rail. My buddy said he had to call FAST multiple times before he finally got someone on the line that was aware of the issue and they actually make a spacer kit for the issue. It was a nightmare and we had no idea why he kept having trouble because the paper work that is supposed to be in the box that mentions the issue was missing so we never knew and the first several times we called FAST nobody seemed to know anything about it. Rant over...
Old Oct 19, 2019 | 01:45 AM
Sounds like its a good thing I went with the 92mm!!! Dang poot you are a wealth of knowledge, thanks man!
Old Oct 20, 2019 | 06:21 PM
00pooterSS's Avatar
No problem man. I did a lot of reading on this site before posting all the time so I got what I know from experience and reading what others have posted up. Just trying to pay it forward. And I love helping.
It doesn't hurt that I've been a tech over 20 years and at master level since 04 and have been obsessed with the LS platform since they came out lol so I try to absorb and learn as much as humanly possible myself.
All that being said, I can't take too much credit, there's guys that know a lot more than me on here that I learn from daily on this site.
Old Oct 23, 2019 | 11:41 AM
ASRoff's Avatar
the Mn12 with a 3:73 is ideal.... 3:90 is getting close to being almost too much... first gear becomes like a rock crawler gear... and if you are going to a 383... it will make even more torque.... for drag racing on a prepped surface 4:10s with a mn12 would probably be fine.... but for occasional spirited driving its way too much gear.... I have a 2002 Z06 and after careful consideration (and what I want to do with the car) I picked 3:73's mine is 60% daily 25% auto cross 15% road course. I talked to Cam motion and we came up with a custom grind cam that gave me Power everywhere (basically a modified titan 4) the LS6 is stock with long tubes, the lifters are Johnson (they are pretty much bulletproof) and the clutch is a RST. I picked the RST because the LS7 is way too heavy of a clutch... in the circle of friends I run with, they are known as synro killers... after driving several different cars with different clutch combos, the driveability of the RST was the reason why I settled on it...again some folks have different agendas with their cars.... I just decided to post what I use my car for and why I made the choices I did..... looking forward to seeing your choices.
Old Nov 1, 2019 | 10:22 PM
So after thinking it over, the heads I have and the cam along with the new FAST 92 I picked up, I went ahead and made the plunge. Texas Speed 383 aluminum short block. K1 crank, TSP H-Beams w/ ARP 2000 bolts, and Weisco pistons w/ 8cc dish and valve reliefs.
