Improving my basic NA set up
If you know someone thats good at welding aluminum they may be able to weld that ear back on with the motor in the car, then you could helicoil or just clean the threads with a chaser and bolt the starter back on.
I've only seen that ear break off a few times over the last 20 years and I suspect it's from the starter bolts not being quite tight enough and the starter putting extra/uneven pressure on that ear, or maybe the inner bolt coming out or breaking and putting full pressure on that outer ear. Don't know if that helps any, just thinking out loud over here.
Cage looks good btw
I've messed with quite a few ls's but i've never busted a block like that on the starter mount.
The australian cars all came with the starter that uses 2 long bolts (same length bolts).. and i have broken the ear off the weaker side of the starter once, from over tightening the bolt on install, but i never had an engine block itself break like that.
I have always tightened the starter bolts probably over torque, at least the one side, because i know that if the starter bolts get loose, it'll probably take the block with it like yours did on start up. So i'd rather risk potentially breaking a cheap starter motor housing on install (like i have done) rather than having not enough torque on the bolts and having the starter bolts vibrate loose after time.
This style starter below is what we have in australia, and i have broken the left hand side ear off the starter (left hand side as you see it below) because as you can see that side of the housing is cut away and it's not solid up all the way between the entire length of the bolt, like the right hand side is, so if you go too tight that ear under the bolt head can break.
So if you get one of these starters that use the 2 long bolts, don't go too tight on that hollow side of the starter, as it can crack the ear off, but you CAN and should go very tight on the other side bolt, which will reduce the risk of the starter ever coming loose.
I don't know what caused your problem but if either or both bolts were loose it would put a ton of pressure on that tab and break it. I've seen that exact scenario play out in other areas when bolts were loose.
Che70velle, I've never seen the starter tab break from a hydrolock on a LS or small block, just rods out the side of the block, is that a fairly common thing for a small block or LS (tab to break off if hydrolocked)?
I gave y’all the longish version there, because if I had said that I’d seen a sbc with 15:1 compression kick the starter off, it would not register. I’ve also seen a hydro lock situation do the same with an iron block LS. Injector failure must have dripped a half pint of gas into a cylinder at DBC and it did the same thing.
ARP does make starter bolts. I have a set on my 434.
Well speaking for myself I appreciate the detailed write up. That's pretty wild but it sounds like they had a lot working against them there (themselves lol).
Also got my hands on a BMR extreme antiroll bar and made it to the track last weekend. Even with a full size battery, the new roll cage and nearly a full tank of fuel was able to make my best pass to date. Every pass but one was in the 6s when a street tire car did a burn out on the line before me and I spun to a 7.0. I'm excited to get to the 1/4 mile and see what it does it's usually almost a tenth quicker than my local 1/8th mile track.
Really happy to be able to get the car going in the right direction again after it was fighting me.
