camshaft grind identification
Old Oct 28, 2019 | 03:45 PM
1994z's Avatar
Default camshaft grind identification
tried google and couple cam manf. with no luck.. cam is a comp cam grind, numbers are j 3116-15 13158r-13037r hr 120.05
i would like to know what company had it ground to their specs. and for what purpose was the cam intended for. n/a, stroker, turbo, supercharger. ect. ect. so no confusion here..
Old Oct 28, 2019 | 04:26 PM
Have you called Comp?? Not to be too obvious....
Old Oct 28, 2019 | 07:59 PM
LilJayV10's Avatar
Crazy talk you speak.
Old Oct 28, 2019 | 10:11 PM
1994z's Avatar
why would you say crazy talk. i have looked up the numbers and know the lift and duration. would like to know the manf. to ask them so questions.
Old Oct 28, 2019 | 10:23 PM
LilJayV10's Avatar
I am really ******* confused.
Old Oct 28, 2019 | 10:29 PM
1994z's Avatar
why are you confused.
Old Oct 28, 2019 | 10:47 PM
1) You want to know the mfr.
2) You said above it's a Comp grind.
3) GUESS WHAT??? COMP MANUFACTURED IT!! They would know.
Any confusion is from statements 1) and 2) from you.
Old Oct 29, 2019 | 07:00 AM
1994z's Avatar
i called comp cams. they dont know who had the cam ground by those serial number. they have no record of it on file. i would like to know what company had it ground to their specs. and for what purpose was the cam intended for. n/a, stroker, turbo, supercharger. ect. ect. so no confusion here..
Old Oct 29, 2019 | 08:34 AM
Darth_V8r's Avatar
Moderator
Idk why comp could not help:
13158r is 226@050 and .605 lift on 1.7 rockers,
13037r is 227@050 and .598!lift on 1.7 rockers.
Its a weird spec. My guess is a turbo spec, but that is a pure guess.
Old Oct 29, 2019 | 08:50 AM
1994z's Avatar
thanks darth. thats what i thought its kinda weird. unless its an old thunder racing design cam. i message btr. cam motion, and little john. cam motion thinks its an older grind.
Old Oct 29, 2019 | 09:17 AM
Darth_V8r's Avatar
Moderator
Definitely not cam motion. The others, not sure. But I would bet there are better options.
