LM7 Collapsed Lifter or Flat Lobe
I replaced my heads about two months ago because the engine was eating coolant. Turned out the dowel pins had sheared and the passenger side head had walked. Now I have an apparent miss and a persistent lifter tick, the truck sounds great but lacks power, it started as a normal tick and slowly has gotten more persistent and louder. You can hear the miss at 2k, but it isn't audible after that. The truck used to hold 40PSI at hot idle but ever since I did the oil change after the oil pressure sits at 35 and only rises up to 45 at 1500ish RPM this is with half a quart of gear oil, it sat at 30PSI at idle before (Gear oil is better for cams because of zinc, but don't do this if you care about your cats). The lifter tick and decreasing oil pressure makes me think its an oil supply issue but I have no experience with hydraulic lifters.
The truck ended up sitting with the heads off for three days underneath a tree, no rain and the block was in excellent shape for 250k miles. I'm worried that some leaf debris managed to get into the lifter oil feeds, I blew the lifter trays out with air but I never inspected checked them. I read here that blowing air through the push tubes can help with a collapsed lifter and I'm planning on doing so tomorrow but are there any other symptoms of a flat cam lobe compared to a collapsed lifter?
Thanks
I would also check to see how much lift that rocker has compared to the others.
I "would" think if the lifter isn't collapsed the rocker arm should have preload on it like the others. If it is collapsed there should be all sorts of slop when you are on the base circle of the cam.
Take the valve covers off first, and follow the instructions that were described.
