Speedmaster MAIN Studs? Use them?
Old Nov 19, 2019 | 10:29 AM
Kfxguy's Avatar
Default Speedmaster MAIN Studs? Use them?
Anyone use the speedmaster main stud kit? here a summit link......https://www.summitracing.com/parts/s...1024/overview/
I'm not trying to be cheap, i'm on a budget and its either use these or stock bolts. My thought process is if they are strong as the stock bolts, they would be worth it to stop the torquing of the bolts in the aluminum blocks threads. Thoughts?
FYI....my reason is this: $250 for ARP studs + $350 to line bore my block = No Bueno for me.
Old Nov 19, 2019 | 10:32 AM
Mavn's Avatar
"I MAID THEESE"
No . Just no . Spend the money on the ARPs. Main boLts are the last thing you want to cheap out on . It's what holds the whole bottom end together lol
Old Nov 19, 2019 | 10:33 AM
Mavn's Avatar
"I MAID THEESE"
Plus youd still need a line hone for those aswell
Old Nov 19, 2019 | 10:34 AM
SLOW SEDAN's Avatar
Both you guys are over thinking the hell out of making basic power.
Old Nov 19, 2019 | 10:36 AM
Mavn's Avatar
"I MAID THEESE"
My theory is. My sbe 5.3 makes 800+ reliably . But if I'm going to do a forged deal it's getting ALL the good **** . Not going to half *** it .
Old Nov 19, 2019 | 10:38 AM
Kfxguy's Avatar
meh....maybe I jumped the gun....looks like they wont work with the windage tray.....
what about these?
https://www.summitracing.com/search/...word=cmb080064
Old Nov 19, 2019 | 10:39 AM
Kfxguy's Avatar
i'm not spending $600 to do main bolts.......especially when thats not a common failure.
Old Nov 19, 2019 | 10:41 AM
Mavn's Avatar
"I MAID THEESE"
what about these?
I like This idea . Brand new GM main bolts.
Kfxguy's Avatar
lol you are probably right
Kfxguy's Avatar
ok....I think thats what i'll do.
Old Nov 21, 2019 | 05:42 PM
00pooterSS's Avatar
Don't fix a problem you don't have
Old Nov 21, 2019 | 11:19 PM
91 Z28's Avatar
Don't run speedmaster anything. Absolute garbage. I bought a set of head studs to try and "save" a few bucks and then one snapped off in the block. Luckily for me I was able to stick the stud back in and find the busted groove and twisted the rest back out of the block
Old Nov 22, 2019 | 08:45 AM
Kfxguy's Avatar
i'm not. I'm still kicking around the idea of running arp bolts. I havent had anyone tell me they had to line hone their block yet. all ive been told is check it.
