Trunion "Upgrade" Failure
none of the rockers installed could be wiggled side to side easily while the associated lifter was resting on the cam base circle (spring closed). They could with significant effort.
also, spinning them once removed, in a certain position they would feel notchy. if i slid the trunnion fulcrum over, no notchy feeling.
this is telling me that grooves are already starting to wear in the bushings. there are only a few hundred miles on this set.
i haven't noticed any noise or loss of performance, though. no man glitter in the oil.
will be switching to the che kit and checking after a few hundred miles.
The theory there doesnt pan out. Especially with how many cylinder heads ive personally and professionally seen and disassembled with nearly every cam you can imagine.
I can guarantee you that the I'd have gotten more run time on the stock rocker over installing the Comp's.
My evidence!
After less than 5,000 miles.
Same as 01CamaroSSTx just posted. Some perfect, some badly failing, some on one side only.
One ****/nerdy thing I did when I assembled mine was to sort through a good pile of used rockers to get 16 with no wear on the face that rides on the valve stem. Then lightly sanded that face with 1000 grit wet/dry on a flat alum plate. Followed that by polishing with jewelers rouge and a buffing wheel. Practically a mirror finish.
Now that they have been run it's easy to see where they contact the valve stem. Not wearing, just have witness marks.
It's easy to see that they don't ride anywhere near the heel of the pad. Nor do they try to run off the toe.
I believe that if you could lower the rocker stands, this pattern could be centered better. I doubt any such part exists to do that.
My cam lift is .617/.598 btw.
It was painful tossing $120 worth of parts in the recycle bin...….
