Another Street/Performance Cam discussion (LQ4)
Old Nov 30, 2019 | 11:47 AM
Sebambam's Avatar
Originally Posted by G Atsma
I agree with you! I didn't know what your budget considerations were.
BUT tagging onto what you say above, get a cam with more than .500 lift and put some good springs in. The old springs are likely worn for even a stock cam. Don't do this 1/2 way...
Oh, and lose the sheet metal intake. They only make power on the top end and lose everywhere else.
might be looking at a tbss intake. I have the stock truck intake as well.
I also have a 102mm tb . Do they fit on oem intakes?
Old Nov 30, 2019 | 12:04 PM
Bspeck82's Avatar
the intake snout is much smaller then the 102TB, for driveability and fitment purposes the GM stuff would work just fine. Tbss is a very good intake, just make sure it's the nbss model. On ebay I saw one that had the Intake, rails and injectors for 400 bucks. Gm TB and MAF are cheap as well
Old Nov 30, 2019 | 12:05 PM
Why would you put a throttle body on that is larger than the throat of the intake? Because that's what you will have putting a 102 TB on a stock manifold.
Old Nov 30, 2019 | 12:06 PM
Bspeck82's Avatar
And any cam that does not require a spring change isnt worth the time. Springs rates need to be increased to compensate for a higher acceleration and jerk profile of the cam lobe. Not needing springs means it's a very lethargic lobe like stock and likely won't make as much power as it does noise.
Old Nov 30, 2019 | 01:38 PM
Sebambam's Avatar
I will see the clearance 1st before I make a intake decission.
the sheet metal intake was for a boost build. The stock truck intake us complete with rails.
If I can trade for a tbss I might do it IF it clears the hood.
let's see
I think both of the intakes I have could work well.. I have seen the sheetmetal ones work on both N/A and boosted of course
Old Nov 30, 2019 | 01:46 PM
The sheetmetal intake WILL run.... poorly. Very little low end power.
Old Nov 30, 2019 | 01:54 PM
Sebambam's Avatar
well then the truckintake it is.
will there be a performance gain with a 102mm (or 92mm) dbc TB? Adapters are cheap I saw (25$)
Old Nov 30, 2019 | 02:36 PM
Sebambam's Avatar
I only think about if I should go.
swap harness and pcm tune?
mailorder tune? do you guys have a good source for a standalone harness and pcm tune?
or
Holley terminator x? Since I have a 4l80e I have to go with the max.
Anybody has some good input/ contacts?
Old Nov 30, 2019 | 03:22 PM
Fast355's Avatar
The one I tuned on a 5.7 GTO engine in a 70 Chevelle had ZERO issues roasting the tires from a stop. Stock stall in the 4L60E and 3.73 gears. Car is on a 295 wide rear tire as well.
The edelbrock proflow also works very well on the 6.0L in my friends 71 Chevelle. With a stock stall 4L80E and 4.10s it effortlessly spins 325 wide drag radials.
Old Nov 30, 2019 | 04:31 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
There are people making 650 RWHP with a ported OE 90 mm tb.
You dont need a 102 till you are well past 500 RWHP and with the cams you are considering, the effort
to use a 102 on a stock intake is pointless.
Old Nov 30, 2019 | 04:34 PM
Fast355's Avatar
Just run the sheet metal and 102mm. The throttle response will be phenominally better because of the large throttle bore. Run a 4" intake system and a 100mm MAF. It will be a much better looking induction system than that ugly medusa looking truck intake.
Unless you 4-link the car or run slicks you will never plant the torque of the 6.0L from a stop anyway on the street. With the 5.3 heads, a cam and a converter it will be spin city even with drag radials
Old Nov 30, 2019 | 04:53 PM
  #32
Fast355's Avatar
Honestly in a classic car I would make the LS look entirely classic.
https://www.jegs.com/i/Holley/510/300-137K/10002/-1
https://www.summitracing.com/parts/sdm-pce138-1002/
Put a standard carb style air cleaner on it. If it has a cowl on the hood, install a cold air kit that seals to the hood.
Run a speed density tune with the MAF deleted. Get the coil covers that hide the coils and make the LS resemble a carb big block.
That is what I would do myself.
Old Nov 30, 2019 | 04:54 PM
  #33
Sebambam's Avatar
it would be pointless if I have to buy it.
But I have it already from a previous boost build
Old Nov 30, 2019 | 05:00 PM
  #34
Sebambam's Avatar
I ll see what fits under the hood Then I decide... I'm not to concerned about the intake right now.
was just wondering.
Old Nov 30, 2019 | 05:07 PM
  #35
Bspeck82's Avatar
Sheet metal will run like garbage. Won't make power till 6000+. Edelbrock proflo or high ram holley is best best for performance with little compromise.
Old Nov 30, 2019 | 05:19 PM
  #36
Fast355's Avatar
The one I tuned on a heads/cam LS1 ran great. Idle, Off-idle, Lugging down the highway in 4th gear with the converter locked. WOT from a dead stop it obliterated the 295s with ease. From a 30 mph roll it still got sideways. Maybe you need to find a different tuner.
Old Nov 30, 2019 | 05:28 PM
  #37
Sebambam's Avatar
I heard the NA opinions about the sheet metal intake.
I bought it a while ago for previous turbo drag build high rpm. So I was not to concerned about low rpm.
@Fast355 yes the tune is very important on that one.
well it's good that I have choices..lol
Old Nov 30, 2019 | 05:30 PM
  #38
Fast355's Avatar
I am not sure what brand it was but it had a 102mm TB on it. The intake runners had trumpets on the end of them. Ran very well on that 5.7. Also had perfect street manners even with the a/c on.
Old Nov 30, 2019 | 06:00 PM
  #39
A sheet metal intake will behave nicely at low speeds (more a function of the cam anyway), but won't make nearly as much power as a stock or FAST. You don't have the flow velocity.
Old Nov 30, 2019 | 06:02 PM
  #40
Sebambam's Avatar
sound like the one i have. I mean they all China rebranded anyways. The welds look good and clean.
I know jegs and summit put there logo on too as well as some "reputable" LS companies.
