2 of 8 spark plugs black
Old Dec 4, 2019 | 09:23 PM
Philhippy45's Avatar
Default 2 of 8 spark plugs black
Ok so plugs 2 4 6 8 are all the same color as well as 1 and 3 but 5 and 7 are black. What could cause this? Injectors were tested fine so were the coil packs. I replaced the wires when I put new plugs in so they're new this is the 3rd set of plugs I put in that side and always 5 and 7 are black... What could cause this? That would explain why they could never get the tune right... Ps: o2s were changed as well second time. Everything was changed and checked the 2nd time now it happened a third time. I'm pretty much at a loss. Any ideas?
Old Dec 4, 2019 | 09:30 PM
Mavn's Avatar
"I MAID THEESE"
Those 2 cylindecs are getting oil In them .
Car down on power ? Do a leakdown
Old Dec 4, 2019 | 09:39 PM
all the spark plugs had oil on the threads not on the electrodes though. Those were the only 2 like that. What could cause it? They're brand new heads and intake didn't really have any oil in it. Also did a peak down and compression test both were fine.
Old Dec 4, 2019 | 10:21 PM
s30.hybrid's Avatar
Oil can also get into the cylinders through the valve seals. You mentioned the heads are new, is it possible a couple of seals were damaged when installed?
Old Dec 5, 2019 | 05:18 AM
I don't see how they were built by Texas speed all i did was install them.
Old Dec 5, 2019 | 06:03 AM
Old Geezer's Avatar
Heads ported?
Old Dec 5, 2019 | 09:02 AM
mintws6's Avatar
How black are we talking here? Were they fouled or just black?
Old Dec 5, 2019 | 09:32 AM
dreadpirateroberts's Avatar
Black could be from oil fouling or from rich mixture.
Possible issue with incomplete combustion or oil control.
Hopefully the guides are good on the heads, but guides aren't known for wearing much unless you are running a pretty high lift cam with stock type rockers.
Could be an ignition or fuel issue.
Old Dec 5, 2019 | 10:05 AM
The shop told me looks like a carbon from not burning right because the other 6 also have oil on the threads but look fine. But why would only 5 and 7 have issues? Everything is new and was checked twice. Could something in the tune cause that? Or would it be all of that bank?
Old Dec 5, 2019 | 11:44 AM
Mavn's Avatar
"I MAID THEESE"
Wouldnt be tune . Would be the whole bank
Old Dec 5, 2019 | 12:47 PM
00pooterSS's Avatar
Did you put sealer on the rocker arm bolts?
Old Dec 5, 2019 | 03:10 PM
yes I did. Could it be a short? But nothing is blowing fuses
Old Dec 5, 2019 | 06:10 PM
We’re injectors flow tested and matched, or just tested to ensure that they were firing? How many miles on build?
Old Dec 6, 2019 | 01:00 AM
swap some of the coil packs around, see if the problem follows them. check the wires, too.
as far as oil on threads, how are the gaskets on your valve covers?
Old Dec 6, 2019 | 03:24 AM
Inj flowed even and gaskets are good as for wiring I would assume that it's good because both coil and inj have power when they're suppose too.
Old Dec 6, 2019 | 04:19 AM
TTur1996's Avatar
Check the easy stuff first. Move those 2 injectors to different spots just to rule them out. If that don,t work move those 2 coils. If that don't work check the harness and make sure all the pins are in place. Sometimes they can push out while plugging them together. Then check and see if you don;t have the rockers too tight not letting the intake valves close completely. Hopefully you don't have a couple bad lifters.
Old Dec 6, 2019 | 04:30 AM
TTur1996's Avatar
I'm not sure what ignition you have but is there any chance you have individual cylinder timing, and those 2 holes have the timing reduced? Just trying to through out there anything I can think of. Also make sure you don't have both coil harnesses swapped from side to side. Motor will still seem to run fine. Won't break up till you hit like 6000rpm.
Old Dec 6, 2019 | 07:31 AM
I switched coils and injectors and still runs like crap. I also checked the wire harness and everything seems fine. As far as I know you can only put the coil on one way where the 4 connect so should br on the right side of the car and as for individual timing I'm not sure what the tuner did its the stock 411 pcm so not even sure if you can to that. I have constant power to them with the key in the on position and when car is running noid light turns on so they're working I even took the rail off and bumped the key and the same amount of gas shot out of all 8 so they all work. I swapped coils around and 5 and 7 still get spark and 1 and 3 still have it. I checked o2 wiring and that's fine I have good grounds and I have continuity back to the pcm for all wires that lead there. So everything is running as it should. Also checked compression and leak down. The last thing I can think of is the tune but i can't imagine how
Old Dec 6, 2019 | 12:01 PM
dumb question, but did you simply try replacing the plugs?
Something is causing incomplete (thus "rich") combustion or oil is getting in there, like i said. Maybe take one of those cheap harbor frieght scopes and look around in those two cylinders.
Old Dec 6, 2019 | 12:05 PM
Something is causing incomplete (this "rich") combustion or oil is getting in there, like i said. Maybe take one of those cheapp harbor frieght scopes and look around in those two cylinders.
we looked and did pretty much everything you can think of this is the third set of plugs I put on and 2nd set of wires... We are thinking possibly tune related some how.
