Unicorn cam?
I ran an LS9 previously and the results were underwhelming. Someone did a test between stock cams and a stage 2 turbo cam, gained 100+hp on low boost (under 15 psi) and low rpm (under 7000). Turbo cam had less backpressure and boost actually dropped a little and still made more power.
I'd go the other way, add another 35% ethanol! Ethanol fuels often help a turbo spool faster and you can run more timing, plus if planned for ahead of time can run more compression. Not sure why people hate on ethanol fuels? Even E50 works great for street cars, not as big an impact on MPG as E85 but almost all the rewards.
All of that complicates matter well more than just putting some 93 pump in and running it.
Most everyone tunes off lambda and so it doesn't matter if you use a gas scale, 11.5:1 on gas scale is still .78 lambda which is 7.6:1 on E85. None of those numbers add any power it's just ease of use to the person behind the keyboard. Most guys that just put 93 pump in the car and run it are pretty slow. The very little hassle required to run ethanol is rewarded by being able to run hundreds more horsepower reliably. E85 is also a cheaper fuel at close to $1 cheaper a gallon then 93, sometimes more. Who really cares if you burn a little more of it when fillups are substantially cheaper.
As far as tests go E50 gives you the relatively the same octane and knock prevention as E85, its certainly worth it in most street cars.
not a fan of the G8. I think it looks like a square wedge from the side because the Smaller wheel well opening in the rear. The front does look killer tho.
Makes me want to stick a 13:1 motor in my car.
As in 75% to 90% and if you dont think theyll give you a different outcome based off MON and RON then maybe you should try them and see.
The difference isnt only in octane but also BTU. And the base fuel itself. Numbers on paper mean much less than real life.
In real life I've run everything from 50-93% on both low and high compression engines, low and high boost. Yet again, this is why having a flex fuel sensor comes into play. You can easily scale A/F ratio and timing to 0-100% of ethanol content without damaging anything. That said even 50% E allows more boost and timing without knock then pump 93, for most people an 11:1 engine on 20lbs is plenty for a street car that still gets decent MPG. For guys that want to push it further then yes we run pump E85 all the time on 30+ lbs without issue. If you want to get saucy then you can run oxygenated E85 but at an increased cost.
Neither are available everywhere at any time.
Try to find e50 at a pump.
This is for the general masses, not someone that is used to it.
The simple difference between summer and winter blends can cause issues also and that has nothing to do with ethanol content there.
Any pump that sells E85 can be E50, its called half a tank of E85 and half 93 lol Tons of people do that, even guys not into cars. Im actually shocked how many normal cars are always at the E85 pumps. Lots of OEM flex fuel vehicles out there!
Again you apparently have no clue how a stock ECM utilizes a flex fuel sensor if you think summer and winter blends matter. The ECM adjusts to whatever you put in the tank, thats the beauty of it percent doesnt matter! More performance when you can run higher content but no damage when you cant.
Either way I dont care if you love pump gas, just means you’ll get gapped lol
If you filled half with E15 and half with E85 would that make E100?
Just depends if each person thinks its worth it to their particular setup. Some people pay for $15+ gal C16, others would rather pay $2 gal for E85, different strokes for different folks. Some guys run M1 in addition to 93 which I did for awhile, but got to the point 3 gallons of M1 didn't last 30 minutes of backroads driving which wasnt worth ~$9 a gal(93+M1 combined).
I understand you're trying to back up your veiws but that is hardly realistic exactly like what i gave instances of and know about the different regions and state laws.
There are quite a few places in Iowa that dont have any ethanol besides the std E10 and that basically all we are known for is corn.
Id rather be realistic for all our customers.
Have you thought maybe to just order boostane? 1-oz per gallon would be more than enough, gets to to 98, and would be easier on you than about anything else you could try. I hated being stuck with 91 in AZ. in SC, with 93 everywhere, i didn't realize how big a difference it makes, but those two AKI points really make a difference.
Edit -- back to your cam question, i reread the entire thread, and i agree WS6Store cam is a pretty good match. Advance wasn't listed, and you may want to install on a 110-112 centerline to help with the torque when the turbo is idle.
