Lq4 budget build advise!?!?!?!
We have an option that would use flat tops instead of the dished lq4 style pistons to bring your cr up and give you or whomever gets it later a brand new engine basically.
Complete rebuild kit is $699 us.
Comes with
Flat top pistons
Drop in rings
Main bearings
Rod bearings
Cam bearings
Head gaskets
Head bolts
Valley cover gasket
Knock sensor grommets
Valve cover gaskets
Oil pan gasket
Front cover gasket
Front cover seal
Rear cover gasket
Rear cover seal
Oil pump
Timing set
AND
How to Build and Modify GM LS Engines book
PM Sent
