Lq4 budget build advise!?!?!?!
I appreciate any feed back on this engine!! Thanks again chris
Last but not least get a decent stall converter. We put a bone stock 160,000 mile LQ4 in my son in-laws 73 Nova with an aftermarket intake and a Yank 3,000 stall converter and long tube headers (Stock cam) and it would do burnouts for days and pulled hard. Earlier this year I put a ASA High Lift Cam from the WS6 Store in it and it has a decent idle and my son in-law is thrilled because he can be rolling along up to about 35mph and get on it and break the tires loose. The next upgrade on that setup will be the 799 or 243 heads with a mild port job. Summit Racing has a line of cams that are reasonable priced to choose from
Socaldave, thank you as well, I know there are a few good tuners out this way so I hoping once iam completed I'll be able to get a solid tune in it!
243 '04-up (LS6/LS2) aluminum center bolt 5.7. Also in some '05-up trucks 64.45cc
799 '05-up 4.8L-5.3L truck heads (these are basically 243 heads)
Basically any head from a truck or car interchange with some exclusions due to bore size or intake port design. To answer your question the 243/799 heads are a direct bolt on for your engine. On the cam check with Summit or one of the vendors, Basically a mild cam can be ground on the stock base circle and you can reuse the stock pushrods as long as the heads have not been milled. You should get upgraded springs, Many are mild enough to use behive springs that aren't very expensive.
Basically think of the LS based engines as sbc in a sense, Most of the parts are interchangeable with some exceptions, Heads/water pump/crank and rods and so on You can even put LS3 rectangular intake port heads on your engine but that would also require an intake to match that port.
I know summit has good things, iam curious to hear about texas speed or speed engineering, i am all for speeding the money even if it means waiting for a while. Is there a difference in quality do you think? From summit vs other companies who sort of focus on these things? Thanks again LLLosingit
When it comes to making it run look at the total cost you'll have into the harness/ecu and tuning software if you plan on tuning it yourself or the cost to have someone else tune it for you...Then look at the Holley Terminator X system and what it's capable of, You might find it's worth the cost. It's a relatively easy to learn system and you don't have to pay a tuner, You can download the software from Holley's website for free if you want to get a look at how to use it before buying.
When it comes to motor.mounts and oil pan it pays to buy something that you know will work together so look at other builds on the same chassis or go with something that was designed to work together, Holley has pretty good line of swap parts also.
We have an option that would use flat tops instead of the dished lq4 style pistons to bring your cr up and give you or whomever gets it later a brand new engine basically.
Complete rebuild kit is $699 us.
Comes with
Flat top pistons
Drop in rings
Main bearings
Rod bearings
Cam bearings
Head gaskets
Head bolts
Valley cover gasket
Knock sensor grommets
Valve cover gaskets
Oil pan gasket
Front cover gasket
Front cover seal
Rear cover gasket
Rear cover seal
Oil pump
Timing set
AND
How to Build and Modify GM LS Engines book
If your bores are good, then just a glaze breaker/dingleberry hone, drop the new parts in, and have some fun!
The only thing you need then are cam kit (like our high lift asa cam mentioned above) and lifters. Thats it!
Let me know if you have more questions.
Thanks
Tech Support
Comes with
Flat top pistons
Drop in rings
Main bearings
Rod bearings
Cam bearings
Head gaskets
Head bolts
Valley cover gasket
Valve cover gaskets
Oil pan gasket
Front cover gasket
Front cover seal
Rear cover gasket
Rear cover seal
Oil pump
Timing set
AND
Thanks
Tech Support
For a "BUDGET" build pull the valve covers and see how clean the engine is. If its fairly clean I would just do a cam, valve springs, push rods and of course long tube headers for your swap. Cam choices are endless but the summit ones are a great for the money. Then just pick a stall to match your cam.
