Achieving desired compression ratio
This would be a fully forged stock stroke motor.
I believe the top piston ring location is determined by the depth of the dish. I'd rather run less dish/flat top with a larger chamber head to have more meat in the piston than running a giant dished piston and tiny cc heads.
And if you can, if you can swing it, I would go larger displacement. Would it be much more to do a stroker since you're already looking at doing a forged crank, rods, and pistons?
Considering reasonable lead times I need to get this ordered within the next couple weeks so I need to make up my mind.
If I stay cathedral and reuse my intake/throttle body, fuel rails and injectors, rockers arms...then all I need to buy is better cathedral port heads to have a reasonable top end in which an better intake/throttle body could be swapped out later easily.
I also don't like buying used parts so picking up a used ls3 top end may seem economical for the performance I don't want to chance used parts.
I recommended going bigger cubes so you have more power right out of the box. A stock LS3 should hold what you want no problem. But if you can sell your current engine you can offset the cost of the LS3 DRAMATICALLY and if you build your current motor you actually are going to spend a lot more.
I would do the build LS3, since that's what you want and have budgeted. I would upgrade to the LS3 top end later when you have the money. GMPP ported LS3 heads are under $1500 new if I remember right and brand new they only around 1200. The intake is about 300 new. I just sold a used LS3 intake for 160. You should be able to put together a LS3 topend buying things for good deals here and there for as much or less than buying cathedral heads, if you are doing ported or aftermarket. And again you can sell your current top end to offset the cost of the LS3 top end.
Just trying to add to the confusion here lol.
