Hate to ask... Cam selection
Old Jan 18, 2020 | 09:06 PM
  #41
Darth_V8r's Avatar
Moderator
Originally Posted by HioSSilver
Depends on several things i have mentioned not even related to the clutch.32 lb isn't even light. That's nothing. That's easier than driving a stock honda as they have 30lb clutches with a 4cyl.
Even the 26lb rps in lazers vette is easy to drive. The 5.5 tilton i run is 16lb. My ex gf dd it in my camaro. I put 40k miles on that set up.
You have to drive it a little different but it can take off from a stop light or be in heavy traffic moving slow w/o ever touching the gas.I didn't....another reason for a light clutch. No cam will match the responsiveness of a light clutch in that application......none.
Rev match down shifting is way better with light clutches as is getting off the corner.agreed
Completely agree on light clutch. I was hung up on the cam specs.
Old Jan 18, 2020 | 09:07 PM
  #42
Darth_V8r's Avatar
Moderator
Exactly what my first post suggested lol. Titan 2 would suit his needs perfectly.
Yup. It isnt constipated
Old Jan 18, 2020 | 10:36 PM
  #43
JF74chevelle's Avatar
It's not about the deal. It's cheap for a reason.
It's about you just slowed your car down with it. There's more to a clutch than just something that engages your transmission. The weight of it also controls the rate at which the engine can accelerate. Think of it as tq management.....mechanical torque management. As tq has increased gm has increased the weight of the clutches to help control it. That means they slowed the engine via weight on the crank.
Another way to put this whole drivability crap to bed is to give you more info. Mustangs has had 40ish lb clutches in them for about 40yrs. Is there drivability issues with them? If not then it's definitely not about clutch weight like some will tell you.
If you think a extra 20lb won't slow you down vs them then grab up 40lb and run across your yard. Then 60lb and do the same. Time yourself. Now consider your only carrying it as dead weight. Then consider your engine has to rotate it thousands of times a minute.
The guy wants better acceleration. He thinks the way to get that done is a cam.........it's not in his case.
And stop exaggerating on my ****. You apparently don't know wtf you're talking or your boosted h/c **** woulda beat my bolt on crap decidedly. On top of that i thaew out 2 more bolt on set ups that either met or vastly exceeded his acceleration expectations. Fact is if you can't get a bolt on ls to the 11s on the stock cam you probably need to look elsewhere. The cam isn't holding it back.......or no one would ever get past the 12s on the stock cam.
I simply offered a different and better way to meet his goals. Which are pretty modest.
its about the deal to me when I’m a 20 year old college student going to school full time delivering pizzas to fund my car addiction. Just trying to LS swap my Chevelle for fun and daily drive it.
Sorry to the OP should’ve said nothing about my clutch set up and just gave the cam suggestion, which I received from a few very knowledgeable people on this forum.
Old Jan 19, 2020 | 12:23 AM
  #44
HioSSilver's Avatar
That's cool.....the deal is sometimes working with what you have. You'll typically learn more like that.
From the first time i ran my car to the last time i ran my car it picked up 1.5 second and as much as 13mph with the same stock cam that came in the ls6. On top of that it didn't get run in it's most powerful form. And i guarantee ya i woulda stretched that to 1.8 second if i hadn't of hurt it.
So when i tell ya it's not about the cam......it's not about the cam. Atleast not until you get some of the other bases covered. Then the right cam could really improve your power.
Old Jan 19, 2020 | 07:51 AM
  #45
WTR388's Avatar
When I originally did my swap the LS7 clutch was suggested as it is heavier and easier to drive. And at the time I wasn't so focused on all out performance. The car orignially was just a fun nice day cruiser but that quickly changed and a few years later now I want to wake it up some more. However, I want some attitude out of the thing and a cam is the way to go. I've done some light reading on air flow rates in comparison with lift and duration etc so I know that yes, I can easily go way too big on cam and kill how the car runs just to say I have a big cam in there, which is why I'm asking. So yeah, being a bit infantile of wanting a car sitting at a light that gets people looking.
I don't expect stock driving manners... And don't want "stock" driving manners, just don't want something I have to rev out to 7000 to hit peak and it can still cruise in 6th at 1500 on flat highway. Shoving it down to 3rd and ripping around someone with a nasty sound coming out the back is part of the fun of the car. Just a weekend warrior car. I live in New Brunswick, I'm not dealing with much traffic, certainly nothing like Toronto or Montreal... And being in Canada, the decision to just upgrade a clutch is not cheap, as we pay an extra 32% to match your $ and then there is shipping and duties, so parts are 75% or more expensive once we get them here.
HioSSilver I greatly appreciate your input, your car obviously performs and you obviously know what you're doing, so a clutch upgrade will be on my radar... I think I'm tearing up my input bushing anyways so I may be going in there sooner than I expect.
Originally Posted by Bspeck82
Bmr did a build for an autox car. I'd focus on suspension tires, brakes and deeper oil and trans pan first. Power should come last.
I spent last summer building and racing a 4cyl car for our local asphalt circle track, ended up winning a race and 3rd in the season as a rookie in a class of well built cars and experienced drivers, came very close to setting a track record in a year where it seemed the top 5 cars were faster and faster every week as we were really dialing them in. And before that I spent a decade racing MX seriously and my big focus as far as the bike was, was suspension as I raced a 250f in a class full of 450s. I had a note book full of settings for different tracks and conditions, and had some money in my suspension set up.
My T/A has full tubular adjustable rear suspension, and I'm working on the geometry of it this summer. Will be doing a weight jack set up, good strut mounts, shocks etc and won't be going cheap on tires either.
Brakes are LS1 swapped with high quality pads and rotors, so as far as that stuff goes, the car is alright.
Considering the BTR stage 2 cam now, bringing the duration down a bit from what I was previously looking at.
Heads are very likely in my future, just not this spring. I'm one of those people that can get carried away with projects like these, I've had to talk myself out of an LSA blower a few times... At least until I get an 8.8 or similar in the back of the car.
Old Jan 19, 2020 | 12:16 PM
  #46
So when i tell ya it's not about the cam......it's not about the cam. At least not until you get some of the other bases covered. Then the right cam could really improve your power.
Lotsa truth in that first statement!
And I like the second one! Too many jump onto the "magic" cam that's gonna transform a stock motor into a fire-breathing ET eater, when it's all the other details that should be addressed first. Mainly heads as far as the engine proper, as you have said. Good stuff!
Old Jan 20, 2020 | 02:35 PM
  #47
00pooterSS's Avatar
I learned the cam isn't necessarily the go to mod out of broke ***-ness and the need to have the utmost reliability. I used to run all over cammed cars in my 2000 SS that had the stock cam and stock **** heads. It had an LS6 intake, long tubes, lanes true duals and a Yank stall and 3.73's. The highly efficient Yank stall and lanes true duals I think were the key things that helped me beat cammed cars that had single 3" and cheap tci stalls.. I even beat a couple stick shift manual trans cars on the highway. It ran 7.6 in the 1/8th on really heavy ZR1 wheels and a system in it. I learned cams aren't always the answer by happenstance. I drove the car 1000 miles a week and drove it really far distances and I was concerned about valve spring life with a decent size cam so the only thing done to the long block was LS6 valve springs. So I fully agree a cam should come last or near last, in a really well done, really well matched, overall setup. I didn't beat all cammed cars, but I beat a lot that were cam and bolt ons only. I couldn't beat a heads cam and FAST intake car with dual exhaust though. Those usually ran 7.2 ish or so. But I wasn't too far off with just a couple of really good bolt ons and a tune.
Also consider the gains when everything is done, then doing a cam, vs doing a cam then everything else. You'll get more acceleration from a well breathing setup than a choked up cam, or over cammed setup..
My current truck has picked up 20 mph over stock, and it's got a stock cam, heads, and intake, even has a OEM catback, but it's from a 6.2 truck so it's a good match to my setup. Throwing a cam in it wouldn't have done that on it's own, but once I do a cam it's gonna come alive now that it can breathe.
I don't deny that the cam is a piece of the entire puzzle. But it needs to fit. And too small is better than too big.
Old Jan 20, 2020 | 10:31 PM
  #48
HioSSilver's Avatar
Pooter....what's a stupid *** flap?
Old Jan 20, 2020 | 10:52 PM
  #49
00pooterSS's Avatar
Best name I could come up for it.
It's a dumb *** flap on a spring that comes in the 2014+ trucks, believe it's half ton trucks only. From what I understand it's there for when your v8 goes into ricer mode. It takes up probably 85-90% of the exhaust pipe.
At 27 seconds
Old Jan 21, 2020 | 06:29 AM
  #50
Tony Vanderpool's Avatar
Im running a Btr stage 3 and it is definetly a head turner. make sure you have a good tuner because cam surge between 1500 and 2000 is an issue
Old Jan 21, 2020 | 12:15 PM
  #51
HioSSilver's Avatar
At 27 seconds
https://www.youtube.com/watch?v=yFYk...ature=emb_logo
that is a stupid *** flap.
Old Jan 21, 2020 | 12:43 PM
  #52
Tuskyz28's Avatar
Old Jan 21, 2020 | 12:49 PM
  #53
How nice of GM to put a choke hold on your HP production. Was there a noticeable increase in power and/or throttle response?
Old Jan 21, 2020 | 02:38 PM
  #54
00pooterSS's Avatar
Increase in power and mpg. Very noticeable in both. But I did a straight through muffler at the same time so both contributed.
The day I did the muffler and cut it out I saw 16 mpg on e85 for the first time ever. highest before was around 12. I also had my mom with me that day so I was easier on the throttle than usual but we drove for hours around town and up and down the highway and cruised down town.
At my little test spot it gained 3 mph, it's approx 1000 feet (my best guess) and uphill
When I wedged it open, I didn't notice a change. Even wedged open it's good restriction to flow.
Old Jan 21, 2020 | 03:19 PM
  #55
TimsLS1's Avatar
I'm currently doing a re build on my LS1 I don't want to rev past the stock LS6 rev limit of 6500 rpm either, I had Crow cams here in Australia do me a custom cam or 217/228 110 LSA (with 0 advance ground in) 2.7 degree overlap on installing I'll likely install it with +2 retard for 219/230. I'm confident It will peak just under 6000 rpm and pull cleanly to 6500 without losing power . When I change gears with m6 it will drop RPM from 6500 to around 5000 and unlike my last cam it will have negligible drop in power when I change. From numerous comparisons I've made I'd estimate difference in 0 to 60 mph times which is primarily what I use it for and a 230 duration Cam is likely to be to be much less than 1/4 second.
If I was using my car for racing or had an auto with torque converter Id think there was really a benefit extending the rpm to 6800 rpm and I'd choose another 10 degrees duration approx.
Old Jan 21, 2020 | 03:24 PM
  #56
Retarding it does not increase duration.
Old Jan 21, 2020 | 03:28 PM
  #57
TimsLS1's Avatar
Yes but it pushes the usable rpm further up in the rpm range similar to increasing duration alternatively advancing it lowers it.
Old Jan 21, 2020 | 03:50 PM
  #58
True, but there is not the gain in power as if the duration actually increased. Really can't correlate the two.
Old Jan 21, 2020 | 03:52 PM
  #59
TimsLS1's Avatar
Thanks I did not know there was not a direct correlation, appreciate the info, I've read lots of your posts. Ill reconsider retarding it.
​​​​​Regards Tim
Old Jan 21, 2020 | 05:03 PM
  #60
00pooterSS's Avatar
Changing cam timing manipulates how much power it makes at a given rpm and IS A TRADE OFF
You retard it for upper rpm power, and lose low rpm power
You advance it for low end, and lose top end
If you do not want to rev the motor don't retard the cam
That's the beauty of VVT. It advances the cam at low rpm and retards it at upper rpm and gives you a BROADER power range, but it doesn't technically increase power in the way that more duration would.
Lets say you measured max power at 5000 rpm. You could manipulate the cam timing to change the power number. If you added some duration to that cam you would make more power AND still be able to manipulate the power at that RPM by changing the cam timing. And if you compared both cams, the higher duration cam (as long as it wasn't too much, were talking if you did say 10 more degrees duration which you easily could with a cam that size) would make more at the same timing. There's a ton more too it but that's a simplistic look at it.
Oh and that cam is way too small lol. You'd get more power by doing other things.
