Budget lq9 build advice
Drop in pistons
Std rings
Bearings
All gaskets and bolts
Oil pump
Timing set
Ls build manual
$699 shipped
Then cam kit depends on what you want they start at $515 and go up
Lifters $130
That gets you everything in great quality and with free shipping for the best price out there.
Let me know if you are interested!
Drop in pistons
Std rings
Bearings
Oil pump
Timing set
Ls build manual
$699 shipped
Lifters $130
I would take WS6store up on their offer. They are quite reputable and well known here for good service and customer care. Plus they will make sure you get what you need, no more, no less. You will be treated fairly.
The ring gap will change and ptb clearance also up and down the bore. Do it once and do it right. It doesn't cost that much more for bore/hone or torque plate bore/hone.
