Ported/milled 243 or Stock 823 on Lq4
Starting off the truck is a 04 2500hd that tows a car trailer 8-10 times a year. Current mods are long tubes, exhaust, 216/220 .550 112lsa with supporting valvetrain, stock converter, ls3 injectors.
Question is, I have a set of ported/milled .030 243’s with a complete tbss intake. I also have a complete set of 823’s also with a complete l92 intake.
Being that the 243’s are milled I’ve seen on other posts compression numbers in the high 10’s to low 11’s, seems awful high for a pump gas truck that’s heavy. I don’t know my piston/deck height currently so it’s hard to get a accurate static/dynamic ratio using calculators.
Stock 823’s obviously make power, but up high where the truck doesn’t live very much, and possibly need a cam with a larger split to take full advantage of the square port heads.
When I get home from work, I’ll have the heads cc’d to get a better idea of a number to plug into a calculator
Anyone have success with .030 243’s in a heavy truck? Or was it a constant battle fighting knock/detonation? What are your opinions on which route I should go with.
The following users liked this post:
Dmax_728 (01-27-2020)
The following 3 users liked this post by wannafbody:
This seems to be the general consensus from most members, unless I was going to go with a Lsa charged later on, which isn’t in the books the I should stick with my 243/tbss set up
G Atsma (01-27-2020)
I have a udp on it, ported tb and ss silverado timing tables. I did a 93 octane tune for it a while back and that pepped it up pretty good but with the mpg's it gets it just wasn't worth it. The 15.9 dragy was on 87 octane.
I bought some oe efans for it a couple weeks ago. It still has the stock exhaust on it but it's starting to fall apart. Had to weld up cracks in the muffler last year so i may do some se headers and their exhaust. I don't want it loud tho because i pull with/load it a fair amount.
A tb ss intake and 90mm tb probably be a good upgrade too. Some 1.8 or 1.9 roller rockers seem to put low and mid range tq in ls stuff which is what a heavy vehicle needs.
yea it's meant to run on 87 octane.
G Atsma (01-28-2020)
Most folks that put the square ports on a 6liter over cam them, and then they seem soggy down low. Last 6liter I built I used the CNC GM LS3’s with light valves. I used offset dowels to move the intake valve away from the cylinder wall, and worked with Tony Mamo on a cam for torque. Had a 219/231 cut for it. This is in a 99 4x4 ext cab that pulls a trailer a lot, and it’s very, very torquey. Used a LY6 intake and a 92mm NW Tb. Align honed the mains with ARP main studs, balanced the assembly using steel H-beams. Didn’t cut corners and paid attention to the details. .045” quench and 10.75 compression. 1.875 headers. Tuned on 93 because that’s all he runs. It works well. Not overcammed and a great working combination, which is most important.
You can probably +500-700rpm for when it downshifts to 3rd from od.
Then on hard pulls in 2nd gear 60mph is about 4k rpm.
Very seldom do i run it harder than that. Usually in 2nd I'm not at full throttle. It just needs the gear.
But that's a typical rpm range it works in.
G Atsma (01-29-2020)
It could be a torque management issue or it could be the converter. What's weird is I drove someone's GMC and it felt different. He had a single cab and I have a crew cab so there might be a weight difference.
I’ve been wondering kind of the same, I drive a stock 6.0 crew cab and wondered if or what would be worth doing without having to run 93. From reading this the 706 heads with their bump in compression is worth more the flow numbers.
http://www.superchevy.com/how-to/eng...nder-head-test
