Summit priming tool
I’m guessing you would need the oil pump drive in place to align the pump then remove it to use the priming tool. Most timing sets with a separate pump drive do slide off and on without being pressed, but I’m curious if anyone here has used it.
Autometer part number 2268 is a M16 X 1.5 to 1/8 npt adapter. Used in conjunction with a 1/8 air hose fitting. $20 turned my motive power bleeder into a oil priming tool. I fill it with about 5 1/2 quarts and that seems to be just enough to get oil out of every pushrod. I use the oil port at the front of the engine so it fills the pickup tube and sends the rest through the filter. I then crank the engine without fuel or spark plugs and have instant pressure on the gauge.
Is is there any issue priming it this way then not having the engine ready to fire for a few days or will it lose its prime?
