5.3L build for truck
- Use the high lift version of that cam with the springs
- Measure piston above deck height and pick a head gasket that'll get your quench in the .037" to .041" range
- Long tube headers
- Trailblazer I6 torque convertor. Either used (make sure it's from a 6cyl) or reman (send your core in).
- Find a good tuner
A more aggressive cam will make your current concerns worse. A small stall and a small cam will help a ton, but the huge tires are always going to be an issue with a 5.3 with stock gearing. For what you're wanting a cam is not the answer man. A even bigger cam is certainly not the answer. I'm on the performance truck forums a lot, where there are a TON of people with 5.3's. There's a guy on there that does a lot of cams and he says the answer for low end is usually these off the shelf cams but on a 110 LSA, which if you type those cams into the cam calculator they just have a super early IVC.
However I would be cautious of the trailblazer converter. I only say that because I would be concerned with the strength of the lock up clutch in a converter made for a much lighter truck. And on top of that going in a truck with huge tires that tows boats and trailers.
00pooterSS - that 6.2 in the video did quite well considering it didn’t have headers and it weighed significantly more. Woulda been a mega slaughter fest if the 6.2 had long tubes and if both trucks were the same weight. Cubes most definitely for the win in a heavy truck.
Mine occasionally hauls the 18' car trailer with my 3rd gen to the track (2800 lb car + 1500 lb trailer) and could probably benefit Greatly form a nice truck cam, which it will hopefully by the end of the year. Along with years I'd also recommend (if not done yet) some LT's. TSP & Speed Eng I believe have Very similar LTs & are both very reasonably priced. That along with a tune, good plugs maybe a step colder (NGK TR6 or equivalent) would help the 5.3. I understand very much so sticking with the 5.3, esp considering the amount of money spent already. It's a commitment already. Main thing with truck came (specifically the 4.8 & 5.3's) to keep in mind is short duration, get those fast short bursts of fresh air in the cylinder and close it off (the intake valve) early for good low end tq. I personally am leaning towards the summit 8718 cam kit or a "high lift" (I hate those coined phrases/terms that get started then every idiot and Jackhole at AutoZone starts using them🙄
cam from Cam Motion.See as how it's mid October, I'm sure you've made a ton of progress since your last post...
https://www.youtube.com/watch?v=8rA2UO4Joec
Same duration(202/202), but more lift (.511 vs. .507) and advanced 2 degrees (+1 vs. -1)
I guess it all helps!
Many good options. Something that's interesting is alot of these entry level/max tq cams (which is what I'm only interested in) seem to feature a noticable difference (more) exhaust duration. Ranging from 4*-12* of a variance of added Exh duration. I'm trying to understand that part...
That's across the board with LS and LT cams. Much larger intake valve than exhaust valve, same air moving in and out, needs a little more time to get out of the exhaust. Also the increased exh duration tends to carry to power a little longer.
That makes sense as far as fighting reversion & scavenging, even with stock manifolds
