Idle vacuum with big cam
This is a 5.3 that was rebuilt 6500 miles ago. And approx 1000 of that after the cam swap.
It was an LMG. It has 799 heads, tbss type intake, 92mm tb, s ummit 8708 cam (10 degrees overlap) LS7 lifters with .090 preload. Summi t springs 140 seat 390 open.
Ebay 1 5/8 headers to sum mit 2 1/2 dual exhaust. Running a 2002 silverado base tune in a 411 pcm.
Warm idle is 65 to 70 kPa absolute which is 8 to 10 in hg on a gauge. It's steady. When it gets hot like a long drive or city traffic it'll get down to 75 kPa. It has ac and a fairly loose converter and idles at 800. IAC counts are 60 to 80 in gear. 0 to 40 in park.
I've tuned it fairly well to about 15:1 idle afr.
Changing the idle timing doesn't help. It has idle spark correction so the advance is all over the place at idle. If I shut this off with hp tuners vcm controls it will surge and stall soon after.
I'd pretty much consider the tuning done but I don't know what to expect for idle vacuum. Shouldn't it be more? Like around 12+ in hg.
You'd need something in the 2-4 degree range to idle in the 55-60 kPa world without changing compression. The 8706 from Summit would drive better and not give up much power given the mods you have. Would make more torque and more avg power actually. It's a 226/230 113 cam. Yeah, it's for turbos, but turbo cams are spec'd like an NA cam if your turbo setup works 1:1 or 1:2 on backpressure.
Probably be faster down the track too unless you're revving it way out over 7k and keeping it there.. aka have a 6 or 8 speed in it with minimal rpm drop/keeping it way up in rpm between shifts. Or a big stall keeping the rpm way up between shifts
If the converter is loose enough you can try bumping the idle to help it out if you don't wanna change the cam compression etc.
When I put it together I calculated 10.3:1 static. It has true flat tops .010 above the deck, and a GM .051 gasket. With this cam IIRC dynamic is 7.4:1.
I've run older engines in the 8.5:1 DCR range on 93 octane.
This was put together to stay mostly stock, but then I went with this cam based on this http://www.cpgnation.com/the-100-horsepower-upgrade/
That cam is nearly identical in specs, not sure of lobe profile. And since the rest of the engine is almost exact I thought why not.
Maybe I'll go for more rpm.
I'd swap the cam to something that works better with your setup man. Or put a 6.0 in with that cam, and bump compression on it a little.
Thats $175 for the short block, I have everything else. Thats what I payed for a 5.7 hemi short block. All I have to do is try harder.
This cam is kind of disappointing given the description they provide. I've had better results putting the cam that worked for that guy in a gen I, one of the last ones I built I did a cam swap to match a magazine article and that alone went 1.5 seconds faster at the track.
When I was building big blocks I would do it right and start with what rpm I wanted to run, then pick a cam to get it there, then get the pistons to get in the mid 8's DCR, the fuel system to feed it, the rotating assembly to handle it, etc.
I haven't yet had a worth while experience with an LS engine, but I'm not blowing money like I used to either.
I'm probably going to put the old cam back in this, it wasn't that slow with it, and it got way better mileage.
This cam here is a great choppy idle only for this engine. I've never had so many random people come up to me and ask about it. Got some thinking to do.
The 282HR example from the link below is a 230/236 in a SBC 350 cube and had 9" Hg @ 800 RPM & 11.5" Hg @ 1000 RPM w/ no load. While not LS based I think this gives a fair idea of vacuum vs cam duration vs motor size.
Comp Cams SBC 350 vacuum & dyno with various cams
Raise idle to 1,200 or so? New cam? Vacuum pump & tank? Live with it as is?
The only thing wrong with that cam is it's a really poor match up to your combo. To be blunt, it was just a horrible choice. Not the fault of the motor or cam.
If you built an LS properly, like you way you described the big blocks, they would run right. Also, you need to do a bigger LS and do it right, going from big blocks to 5.3's is going to be depressing. But a well built 6.0 or 6.2 is pretty damn impressive and can easily stack up to some big blocks. A well done 6.0 or 6.2 can put down 500 ft lbs and 600 hp (flywheel) without getting to expensive or wild, needs to be properly planned out but probably doesn't cost as much as you might think. Good compression, LS3 heads and intake and the right cam will put you damn close and all that dont cost much at all. (flywheel). 5.3's are just too little. I can talk **** about them, I have one. I call it my baby dick motor.
I think it's just never mattered before, vacuum was what it was. But now that I've tuned it with a factory PCM, I'm realizing how much it effects how it runs.
I think I have it tuned as best as it's going to get, but yet there are some very minor quirks to fine tune if I want to. Or call it good. But it's either not fast or I got used to it.
Is a 4.5 second 0 to 60 mph fast for this set up in an S10 with pretty good traction but not from a stop? The problem is I also have a video of the old cam (a '02 LS1 cam) doing a 4.7 0 to 60 mph. AND I have an '09 Charger with a 0-60 timer that will get 4.9, 148,000 mile ex patrol car with 13,000 hours on it and 4000+ pounds. Nothing seems fast I think because my crap is all slow.
Either put the cam in a 6L with the 799 heads (between the displacement and compression it should at least work better) or go with the cam JakeFusion suggested. Might even be happier with the 8720.
If you want to keep this cam put a 5k stall in it and a short runner intake and turn the idle speed up quite a bit and rev it out to 7500
In my opinion 4.5 isn't very good at all for a stalled cammed v8 s10. I'd want sub 3 second 0-60
I bet you would be faster with a stock cam from 0-60 if it's all setup well.
That's the truth right there. Even my first Gen I was a 400, I'm going backwards here.
