Worktruck build up
Old Mar 19, 2020 | 03:54 PM
lsxKC's Avatar
Default Worktruck build up
So the story goes about a couple weeks ago my f250 shot craps and I needed to get myself an truck so I bought a 2001 GMC Sierra SL single cab 2wd long bed V8 4.8 anyways so I figured to build that up rather than put the 4.8 in an s10 or a foxbody anyways I'm a huge fan of having my cake and eating it to so I'm thinking for stage 1
*sloppy stage 2 cam
*Tbss intake
*Pac1218 springs
*92mm throttle body
*Holley fuel rails
just for simple bolt ons as this is my daily driver see where things go from there
Old Mar 19, 2020 | 08:58 PM
Ls7colorado's Avatar
do not cam that truck unless your gonna do a stall
Old Mar 19, 2020 | 09:39 PM
68Formula's Avatar
You didn't mention gearing, torque convertor, max shift rpm, or what you expect in terms driveability. You've picked a pretty stout cam for a small 4.8L, moderate static compression, and no boost.
Sloppy works great in some combos, and poorly in others. Give more details, and I'm sure you'll get some better suggestions. And if your picking the cam based on cost Summit has some very affordable grinds that will be much better suited for a small displacement, mild compression. NA engine.
Old Mar 19, 2020 | 10:06 PM
lsxKC's Avatar
so like a 3000 stall
Old Mar 19, 2020 | 10:08 PM
lsxKC's Avatar
Yea stage one is just getting it prepared for boost
Old Mar 20, 2020 | 07:15 AM
68Formula's Avatar
If you want a cam that works well with boost, but will also be tolerable as a NA in the meantime; the SUM-8715 is a better and still economical choice.
Old Mar 20, 2020 | 07:43 AM
Agree with the SUM-8715
If you wanna prep for boost then all you need to do is buy a fuel pump and injectors lol
Old Mar 20, 2020 | 05:53 PM
00pooterSS's Avatar
The sloppy stage 2 cam is HUGE for a 4.8
Would work well in a s10 with a 5k stall and some short gears, not so much in that truck though.
