lq4 build
Old Mar 20, 2020 | 07:05 PM
mopar21440's Avatar
Default lq4 build
hey guys, just joined the forum. Starting my LQ4 turbo build. If i go with LS6 cam, what pushrods and lifters should i use? i see LS6 is popular cam to pick, if someone has different idea please chime in
Thanks in advance everyone
Old Mar 20, 2020 | 08:23 PM
LS7 (common replacement) lifters, 11/32 x .080 chromoly pushrods
Old Mar 23, 2020 | 07:12 PM
mopar21440's Avatar
is there any specific year variants I need to pay attention to? like what year LS6 cam I want?
Old Mar 23, 2020 | 07:53 PM
68Formula's Avatar
Back when LS6 take out (used) cams were easily available and cheap they were popular. But there are much better choices available depending on what you'd like to get out of it
You should post up more details like vehicle, gearing, trans, torque convertor stall (if applicable), max rpm, power adders (nitros, turbo, etc.), intake, header type, and how you'd like to use it (towing, street, street/strip, strip only). Then you should get some better suggestions.
Old Mar 25, 2020 | 06:54 PM
mopar21440's Avatar
@68Formula Good point my apologies for the lack of information. Build is in the part acquiring stage short of block back from hot tank. I installed new cam bearings and deglazed cylinders. Not using stock pistons and rods.
1993 mustang GT
373 rear end
4l80E
Not sure of converter yet
Max RPM isn't to important (street car mainly)
Turbo (leaning towards EBAY GT45) but only temporary
stock truck intake
single front face turbo manifold with cross over
car will be a driver, and go to track sometimes for fun
I am throwing it together if you will just to get LS powerplant in car and drive and feel it out. I don't have a horsepower goal so if it makes 600 or 1000 it doesn't matter because its not going to stay in this form to long. I was making a bit over 500 to tire with stock 302 with vortech charger and heads. Its my first LS swap but definitely not my engine build. I know the community is the best for info as you guys have some amazing builds and projects going. I appreciate all the input very much. Thanks in advance everyone
Old Mar 25, 2020 | 08:09 PM
68Formula's Avatar
Probably go with the SUM-8706 Summit Stage 2 Pro LS Turbo.
Old Mar 25, 2020 | 08:44 PM
68Formula's Avatar
Here's a member using it in a similar combination.
Originally Posted by wes302
My combo went 9.0 at 149 in 3050lb fox with vs racing 78/75 next gen
6.0 ly6
Summit stage 2 turbo cam
Carb blow thru
Upgraded to t6 85/96 vs racing
Th400 4k stall fti turbo converter
3.55 gears on 275 radial.
Old Mar 26, 2020 | 06:15 PM
mopar21440's Avatar
Awesome, thank you very much for that information. Looks like that's the one I will go with (specs look very nice). As far as piston and rod choice, there are a lot of different options. any recommendations on a piston rod combo that are reasonably priced? I have a few in mind just wondering what everyone likes to go with on a budget?
Old Apr 19, 2020 | 11:21 PM
mopar21440's Avatar
Hey guys. Got the summit stage 2 turbo cam. I also got https://www.summitracing.com/parts/SUM-326945400012 these pistons. I ordered the matching rods but no stock for 6 months. Im wondering what you guys recommend as another option. I need to get rods, lifters and pushrods still. Stock crank being used. any recommendations? also what timing set works well with that cam? i got a cloyes but no torrington bearing included and i cant find a good explanation if i need one or not (i havent checked thrust play simply because im not sure of the desired operation style for the cam gear with or without bearing which i believe .001 ish is wanted correct me if im wrong).
Old Apr 30, 2020 | 08:24 PM
mopar21440's Avatar
Hey guys, sorry for the lack of updates its been a slow process as i have so much other work to finish. Ordered Wiseco pistons and K1 rods with king mains and clevite rods. Should be here in a week. Then gap rings and get rotating assembly together to check clearences. I got -3.2cc flat tops hoping with my 6.125 rods and .052 head gasket, should be around 10/1 CR. Ill see where the piston ends up on TDC and if i have to change head gasket thickness i can. Want to stay with pump gas and meth if needed. I got block painted and my cam bearings installed. Once i get the cylinders honed and rings gapped ill post pics. Block is painted. Ordered all the little things that should be here any day such as ARP hardware where needed, new front and rear covers, lifters, oil pump etc. Its coming along but slowly. Love this site, lots of great people and great info.
